WeatherTech Front Mud Flap - New Style
WTGuy
Bolingbrook
BMW
Any idea on when these will be available? I just checked the website for ‘26 Bronco and didn’t see them listed. Thanks!
They just haven't been audited yet on a 26' vehicle and updated on the website. As long as nothing changed from 25' to 26', they will be the same part number. Order a 2025 set and you should be good to go.
WTGuy
Bolingbrook
BMW
that gap is ridiculous which is why I sent mine back. That version looks like it is a one style fits any car mudflap that you would find at a gas station.
to weathertec - is the new version a real drill less application? I have your rear ones which required drilling even though you claimed drill less.
There is no drilling or piercing at all on the fronts. You just need to remove some fasteners and install some new ones.
The rears require "piercing" as there's no other way to install and attach to the bumper.
WTGuy
Bolingbrook
BMW
My original rears required drilling through the plastic inner fender liner, even though it stated 'no drilling'. And the fronts that I returned would have needed a hole drilled/punched through the inner felt liner.
I believe the felt you're referring to on the front just needs to be tucked behind the bolt hole. There's no need to drill or punch through it. Simply tuck it behind the hole so that you can access it and put the supplied bolt through the hole and mud flap.
You can see here the felt tucked behind the hole.
Ford Bronco WeatherTech Front Mud Flap - New Style felt
SideTrackTap
Grand Haven, Michigan
2004 Ford Freestar
Awesome. Thank you!
