Weathertech for 2door with rubberized floors
mikejames
Canada
Bronco Black Diamond 2 door
I'm looking at Weathertech's laser measured floor liners for my '23 2-door Black Diamond. Weathertech.ca (I'm in Canada) shows only front mats for the 2022/2023 model years, but front and rear for 2021. Part numbers are...
2021: 441702-1-3V
2022/2023: 4417021V
Any reason the 2021 won't fit my 2023 Bronco? Seems like they would not have changed but maybe someone knows better?
Ford Bronco Weathertech for 2door with rubberized floors Screenshot_20230327_215226_Chrom
Ford Bronco Weathertech for 2door with rubberized floors Screenshot_20230327_215134_Chrom
I assume these are the correct ones for my rubberized floors... Weathertech has a popup that seems to direct you to the right product based on your selections (2/4 doors, carpet/rubberized flooring).
I've already tried a set of Huskyliners Weatherbeaters, which did not fit well over the rubberized floor. The spikes on the undersides were definitely part of the problem but worse was that the fronts wouldn't snap onto the retention points (even after shaving off some of the underside spikes). Compared to my OEM mats, the husky's snap mechnism was deeper - I think must be meant for a carpeted floor. I've heard the X-act Floorliners are Husky's answer to rubberized floors, but I don't have anywhere to buy them from in Canada, so I'm back to Weathertech I guess...
BigHoof
PA
Ram 2500
I just got the Weathertechs for my 2023 2 door Badlands last week. For some reason, the configurator is wrong. I had stumbled onto the 2021 info or would have gone a different direction. I did contact WeatherTech to let them know. Ordered the 441702-1-3V, they fit like a glove.
Generally go with Huskys but they only offer the one version which has the nubs on the back so ruled them out.
mikejames
mikejames
Canada
Awesome! This is exactly what I was hoping to hear. I figured they wouldn't have changed anything between 21-23; maybe it was just that they never properly updated their system to reflect the newer years... I'm always amazed how manufacturers can miss this kind of stuff... yes they have endless models to keep track of, but they go to the trouble of setting up the website after all, and their whole business model relies on people finding the right version for their exact vehicle...
Do yours snap onto the retention pegs in front? I assume the weathertechs work like the OEM mats in this regard, but that was the major fail on the Huskys.
BigHoof
PA
Ram 2500
Yes, they snap easily onto the pegs. Thee is also a cover over the pin hole like you see in the picture. The fronts extend nicely over the sill.
If you need anything more specific, let me know and I'll try to help best I can.
Tilzbow
NV
GM Sierra Diesel Pick Up
I’ve got Husky’s in my two door Badlands and they snap into the front retention pegs.
Ford Bronco Weathertech for 2door with rubberized floors 13C01550-69B1-4E55-8B03-6AC8CC2E6AD8
Aloha Sunrise
Hawaii
2021 Toyota Tacoma TRD off road,1971 VW shorty bus
Have Weather Tech in my Tacoma and Husky in the Bronco. Husky has better coverage and stays in place.
BroncoAZ
Mitch
I’ve got a 2021 2 door with the washout floor. The Weathertechs fit very well.
BigHoof
PA
Ram 2500
I've got the Husky X Act fit in other vehicles but in this case, the WeatherTechs are the way to go. Even Ford does not use mats with nubs on the rubber floor. Can't be good for it over time.
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
I have Huskys in my Black Diamond. I cut off all the nubs and they snap in and fit perfectly.
Bad-Daddy-Lands
Todd
‘23 Bronco, ‘21 F250, ‘96 911/993
I have Ford all-weather mats in my BL with washout floors and they are real nice…fit perfectly. Not to mention they have Ford and Bronco logo. Good luck.
Roger123
Roger
VA Beach, VA
Another satisfied factory mat user here!
mikejames
mikejames
Canada
Are your huskies the x-act contour version? Turns out I might be able to get those after all.
kr_1315
Kevin
Houston, TX
Yes. Husky 55941 is the part number. I’m very pleased with the fit and look after cutting the nubs off with angle cutters.
BroncoAZ
Mitch
That sounds like way more work than it’s worth.
