Water Leak Front Passenger Visor
Madeinoregon08
Jonathan
Oregon
2024 Bronco
I've talked about this in another thread, but I don't want to hijack his thread..... Been going on for a while. I have to drive with a bath towel folded up sitting on the dash to catch the water that runs down the passenger side visor whenever I make a hard right hand turn. It's been in several times and they say they've fixed it. I took the front part of the hardtop off the other day and saw that they just applied silicone around the screws that hold the seal that runs on the top of the windshield frame. I just got this on November 14th and for a 70k vehicle I'm not pleased with this solution(?). If applying silicone stopped the leak, should I be happy? Or should I not accept that as a fix? I'm worried about down the road after warranty, it getting worse and now it's 100% my problem....
Ford Bronco Water Leak Front Passenger Visor 20250102_140135
Ford Bronco Water Leak Front Passenger Visor 20250102_140144
Ford Bronco Water Leak Front Passenger Visor 20250102_140128
Madeinoregon08
Madeinoregon08
Jonathan
Oregon
2024 Bronco
Mine has the same leak on passenger side... hoping that thread had some sort of resolution.
guess I will keep searching...
Sorry man, pretty frustrating. In the other thread, the OP'r is waiting on a national backorder seal. Which i think I should have been given too........... Good luck, if you learn anything hit me up and I'll do the same!
helifino16
Ron
Mount Sinai, NY (Long Island)
Have you checked to see if the mirror washer button is activated?
lol
userdude
Denton, TX
2023 2dr Badsquatch
I had a leak the first week and it turned out it was a seal along the top. Ford replaced it under warranty, as well as the rear window seal. Take it to your dealer service.
Madeinoregon08
Madeinoregon08
Jonathan
Oregon
2024 Bronco
I guess there's a little more to it. When I took delivery I immediately noticed the pool of water on the dash that somehow (I have no idea how), they weren't able to see during the PDI. They took the top off and told me that 2 screws are completely loose and are not tightening, like whatever they thread into is stripped. Then after 2 visits, miraculously it's fixed.... And all I see is silicone.
