Wait or Get a Badlands
jaspercasidino
PNW
2022 Bronco
It's kind of an important mode...one that's used all the time on other trucks in the Ford line-up....so I definitely see the point. No one buys the Bronco for speed, but that doesn't mean you don't want to max the capability of what it is on the road too, and if normal has the throttle reponse like some Ford vehicles and super early shifting, thats a problem.
Thank you! Every time someone mentions Sport mode some people inevitably come out and assume the person wants to drag race and put down 12 second quarter miles. Not to mention the people saying Baja is Sport mode in 4H and to just switch to 2H. I’d love to see where that is written!
OspreyFE55
Marc
Navarre, FL
2013 Smart ForTwo
Small correction, Badlands and FE get Rock Crawl instead of Sport. BL, FE, and WT all have Baja.
I was referring sport to Baja. I knew BL had Rock
OspreyFE55
Marc
Navarre, FL
2013 Smart ForTwo
What would you like to see written? That Baja is 4h compared to Sport being 2H?
Brownie
Maple Ridge, BC Canada
Bronco Badlands, 1981 Trans Am, 1972 Austin Mini
Most likely a 80+ hp bump here on the conservative side.
Ford Bronco Wait or Get a Badlands B9923B2C-C0FA-47D9-A244-AD56A620E9E4
lowmpg
Ryan
Maryland
F350
As soon as tunes hit specific to the Bronco 2.7, it will negate a need for 'sport' mode.
jaspercasidino
PNW
2022 Bronco
I would like people to stop passing that one guy’s post as fact when it is pure conjecture. Feel free to research the Raptor’s Baja and Sport mode differences from user experience and Ford publications to see that, at least on that vehicle, there are substantial differences between just switching between 4H and 2H.
Aman
Aman
Northern NJ
According to Raptor owners, Baja is not simply Sport in 4H. I wish it was, but think FORScan can help us with replacing another mode with Sport.
Brownie
Absofrickenlutely! With the 2.7, wheelie bars might be in order....
lowmpg
Ryan
Maryland
F350
People seriously haven't spent time investigating the tunes available for the 2.7EB I think. No need to 'wait' unless you just want suspension and body cladding. You can create a beast for little money. That 2.7EB in the F150 is no joke. Now sure, you could wait for a 3.5 or something but for most peoples purposes a tuned 2.7EB is way more than enough.
Spooled
Republic of Texas
Raptor, Model 3
Yea, being in the Midwest, we don’t have a lot of options for crawling, etc...so speed is important
Just push the accelerator pedal down further and you'll get the same effect. It doesn't magically make it faster. Sport mode just adjusts the pedal position tables relative to your throttle input. It ramps in pedal position more aggressively with lighter throttle input. It does downshift more aggressively, but do you really need that?
If it's that important to you, put an aftermarket tune on it or a Pedal Commander if you don't want to tune it.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Getting my 2.3L manual BL now/asap, unless I get pushed to MY22. The Bronco with turbo will have more power and speed than what I'm driving now (Mitsu 2.0L manual 4-popper).
lobbs611
Kyle
Independence, MO
2D JL Rubicon
Is that tuner available on other Ford vehicles now, where you can go in and just swap a mode? Eco would be gone before I got it home in that case.
As far as the Baja=Sport thing, it doesn't seem to be the case on Raptor from all reports. The myth that they were the same seems to stem from a made up chart from someone guessing what the modes would be like, that is now passed around like it's a Ford document.
I'll ask our tuners at work and see what's available for Fords. I know when they tuned my car they copied all the Sport mode tables for my transmission (shift points, line pressures, etc.) over the Normal tables. So basically I'm in Sport mode all the time without having to use the paddle shifters. That's a GM though. If they can access the tune tables I don't see why they couldn't swap known values from one mode over another one.
Gamecock
That would be awesome, if you could just go get something like that to replace Eco.
  • Like
Reactions: BD1
RRaptor
Rick
2024 Badlands
I don't put my Raptor in Sport mode since I had a tune. Cobb tuning allows the mapping of the gas pedal so all the sport tune does is just hold the revs higher in every gear.
I am going with a Badlands and will trade it in at the first opportunity for a Warthog if it is a 2 door.
