Valhalla
Valhalla
Valhalla
Chattanooga Tn
Got the rear foam done....
Starting on the bed insert
Ford Bronco Valhalla's Long term build thread 20260217_115231
Valhalla
Valhalla
Valhalla
Chattanooga Tn
Not much done today, had to put a battery in the HEEP and make wires to plug in a tricklecharger on it.
Finished some holes in the bed plate.
Ford Bronco Valhalla's Long term build thread 20260218_131538
Valhalla
Valhalla
Valhalla
Chattanooga Tn
Got the holes done started cutting pipe. This gives the idea of my plan.
Ford Bronco Valhalla's Long term build thread 20260219_130937
Ford Bronco Valhalla's Long term build thread 20260219_130952
Ford Bronco Valhalla's Long term build thread 20260219_122141
Valhalla
Valhalla
Valhalla
Chattanooga Tn
This is so going to work!!! Some bending then decide if I'm srewing it on or making a piece!!
Ford Bronco Valhalla's Long term build thread 20260220_010656
Valhalla
Valhalla
Valhalla
Chattanooga Tn
More done on the bikini
Ford Bronco Valhalla's Long term build thread 20260220_141624
I literally had to have a beer before I drilled holes in my windshield frame so I could do what I really wanted with my truck.
Ford Bronco Valhalla's Long term build thread 20260220_121825
Looks good I'll have to see how it is at speed. This is just the fit process. I'll be securing the straps to the bed cover.
Ford Bronco Valhalla's Long term build thread 20260220_141503
I heated the pieces to bend them easier; this made it where I had to shoot some paint on it.
Ford Bronco Valhalla's Long term build thread 20260220_110317
My limb risers had to be trimmed to make the top fit in the channel.
Ford Bronco Valhalla's Long term build thread 20260220_112500
Ford Bronco Valhalla's Long term build thread 20260220_110338
Ford Bronco Valhalla's Long term build thread 20260220_141453
Valhalla
Valhalla
Valhalla
Chattanooga Tn
A few more pics. I used 1/8" wire rope to attach the cover to the d rings .
Ford Bronco Valhalla's Long term build thread 20260223_112446
This is what it currently looks like.
Ford Bronco Valhalla's Long term build thread 20260221_153159
PWillette
Parrie
Maine
Valhalla
Valhalla
Valhalla
Chattanooga Tn
Anyone tearing apart rear seatbelts to remove them and not have a warning: they are 3 pieces the case snapped together with 2 one way rivets, the mechanism, and a proximity sensor. Buy 2 right belts, (cheaper) for the sensor.
Ford Bronco Valhalla's Long term build thread 20260310_120507
Ford Bronco Valhalla's Long term build thread 20260310_120516
Ford Bronco Valhalla's Long term build thread 20260310_120533
Ford Bronco Valhalla's Long term build thread 20260310_120544
Scooter M'Gee
Cincinnati, Ohio
2025 Ford Bronco Squatch 2 Door
You were much more surgical than I was tearing those apart. The replacements I bought were Dremel'd and hacked apart. :devil:
Valhalla
Valhalla
Valhalla
Chattanooga Tn
Yeah, I wanted to see how feasible it would be to remove and replace in stock belts.
vrtical
Doug AI
GSMNP, TN
Fords
why dont you Forscan the seatbelt stuff? I have mine all turned off.
Valhalla
Valhalla
Valhalla
Chattanooga Tn
This was sensing the airbag sensor wasn't there where I removed the lap belt connection.
It's a removing rear seat thing.
