Valhalla
Valhalla
Valhalla
Chattanooga Tn
Ford Bronco Valhalla's Long term build thread 20230505_093722
wired in
Ford Bronco Valhalla's Long term build thread 20230505_093738
my extrcoil of wire is for when I build the rear winch bumper.
Ford Bronco Valhalla's Long term build thread 20230505_110642
putting out at 38 psi to 4 tires at 0 psi, it took 14 minutes to inflate all 4 to 38 psi
deesle
Ryan
Lobo, Texas
2002 7.3 Excursion, 2014 6.7 F-350
@Valhalla ARB sent me the PDF with color photos. Clearly has the washers on the bolts.
Ford Bronco Valhalla's Long term build thread 1683910698822
Valhalla
Valhalla
Valhalla
Chattanooga Tn
Valhalla
Valhalla
Valhalla
Chattanooga Tn
I appreciate it man!!
Valhalla
Valhalla
Valhalla
Chattanooga Tn
I put in my midland 275....
Ford Bronco Valhalla's Long term build thread 20230702_150741
Ford Bronco Valhalla's Long term build thread 20230702_150739
Ford Bronco Valhalla's Long term build thread 20230702_145948
Ford Bronco Valhalla's Long term build thread 20230702_145940
Ford Bronco Valhalla's Long term build thread 20230702_145930
Ford Bronco Valhalla's Long term build thread 20230702_145927
Ford Bronco Valhalla's Long term build thread 20230702_145847
Ford Bronco Valhalla's Long term build thread 20230702_145842
Ford Bronco Valhalla's Long term build thread 20230702_145815
Ford Bronco Valhalla's Long term build thread 20230702_145704
Ford Bronco Valhalla's Long term build thread 20230702_145700
Ford Bronco Valhalla's Long term build thread 20230702_145630
Valhalla
Valhalla
Valhalla
Chattanooga Tn
It an be a little hard to hear with the speaker below the center trim. I plan to add an external speaker later. I wire it to number 5 on the switches. There are a lot ov video's on removing the trim panels and the dash. Be careful of the pedals when routing the antenna wire.
Valhalla
Valhalla
Valhalla
Chattanooga Tn
I like it this way because it's easy to remove the mic when not on use.
Ford Bronco Valhalla's Long term build thread 20230716_105014
Ford Bronco Valhalla's Long term build thread 20230716_104940
Valhalla
Valhalla
Valhalla
Chattanooga Tn
It's not done, I'll post more once finished and it has a winch.
Ford Bronco Valhalla's Long term build thread 20230809_111633
Valhalla
Valhalla
Valhalla
Chattanooga Tn
I did not like that I could not open my back glass, with the gate closed, with the high lift on. My solution was to buy some cheap eBay JK hood hilift holders.
Ford Bronco Valhalla's Long term build thread 20230904_145307
Ford Bronco Valhalla's Long term build thread 20230904_145236
Ford Bronco Valhalla's Long term build thread 20230904_145245
Valhalla
Valhalla
Valhalla
Chattanooga Tn
These were here when I arrived home from work:
Ford Bronco Valhalla's Long term build thread 20231003_000724
They are crossmember skid plates.... I need this because...
Valhalla
Valhalla
Valhalla
Chattanooga Tn
First straightened these up some.
Ford Bronco Valhalla's Long term build thread 20231016_180911
Ford Bronco Valhalla's Long term build thread 20231016_180923
