Updated 2.3L coming?
McLovin80
Thomas
Greensboro, NC, USA
26 Badlands (Pending), 23 Golf R, 95 F150, 95 Prelude
I see the 2024 mustang is getting an updated 2.3 engine with port and direct injection.
Will the 2024 Bronco receive this update too or just the same 2.3 as before?
Lowcountry Bronco
William
South Carolina Lowcountry
Same, haven't heard when/if we'll get the new setup.
McLovin80
McLovin80
Thomas
Greensboro, NC, USA
Lowcountry Bronco
William
Makes sense. I guess Mustang performance vs Bronco/Ranger performance are completely different agendas.
It might not be a bad thing to let the Mustang teeth it for awhile.
Rusty Sheckelford
Rusty
LA
Seems weird that ford would sell 2 different versions of the same motor, but as someone else said maybe let those guys be the Guinee pig.
GoHack
Palmdale, CA
'25 Bronco, 2.3L 4-Cylinder, 7 Spd. Manual, 4 Door
The "BIG" advantage w/the port/direct injection combo is due to the problem w/the carbon buildup on the valves w/the present direct injection system.
The valves don't get washed off w/direct injection, as they do w/the port injection.
So it's a combination of the best of both worlds.
Toyota has been using this combo for a while now.
The best way presently to keep the valves free of the carbon w/the present direct injection system, as best you can that is, is to:
1. Use a good detergent Tier 3 Fuel like Chevron w/its Techron.
2. Perhaps the most important thing, not to do shorties around town, especially in the winter, which don't allow for the engine to get up to full operating temperature. Take her on the highway in order to get her up to the full operating temperature.
Add some Techron additive to the fuel tank once a month.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Yeah, that’s a major concern for me. My commute is just over a mile. I try to drive it a bit more - but, some days I just want to get to work and home. I used to use Techron in my VWs…perhaps it’s time to research that more for this vehicle.
McLovin80
McLovin80
Thomas
Greensboro, NC, USA
I work from home so the average trip is a short one. I usually let my vehicle get up to temp before driving, which doesn't take long in FL, and I run 93 everytime.
I have had several turbo vehicles but never ran a catch can. I prefer an AOS if available.
My favorite turbo was the 2.3 DIZI in my Mazdaspeed3. My WRX STi had the best aftermarket IAG AOS set up, but that 2.5 boxer engine had more flaws than any other turbo I owned and needed all the help it could get.
redone17
Cold Spring, NY
IAG just released the AOS for the Bronco. What’s the difference between that and a catch can? I thought they were the same difference.
I want to get one for our Ranger - but, I’m dreading that install.
Fmuguira
Frank
Idaho
Jeep TJ
Do they mention if new engine getting a HO/TQ bump??
if so probably have to get the 2.7 EB a little more also as inticement to potential buyers…
McLovin80
McLovin80
Thomas
Greensboro, NC, USA
This is my dumbed down descriptions:
Catch can is literally just as it sounds. It catches the "blow-by" (aka the oil and fuel vapors) allowing it to condense and be drained.
An air-oil separator (AOS) filters/separates air from blow-by and sends it back to the crankcase, so there's nothing to drain.
AOS install is more complicated than a catch can but worth the effort.
I noticed Ford makes an AOS for the 2.3 https://performanceparts.ford.com/part/M-6766-B23 which looks pretty easy to install. I might go that route, since it's OEM.
McLovin80
McLovin80
Thomas
Greensboro, NC, USA
Ford's website is showing the same specs as 2023 on the B&P page 275/315 or 300/325 with premium gas.
Definitely not complaining as those are still solid numbers, plus you can get the performance pack to bump up to 330/385.
Lowcountry Bronco
William
I think you and I were looking up the same thing, here's the thread on the Ford offering
https://www.bronco6g.com/forum/threads/ford-performance-air-oil-separator.74053/
I'm not very knowledgeable on this topic but doesn't the 2.3 already have an AOS? Lots of back and forth on the catch cans but with my own 2.3 on the way I be want do my best to keep it clean.
l88m22vette
IL
Please sir may I have locking diffs?
I'd love this, especially if someone figures out how to swap the setup.
That's actually a catch can, since you can remove the lower portion to empty it out. I do agree about an AOS, I have a catch can on my TT and it does collect fluid but not much, and plenty of Subaru guys like the IAG. I had a turbo Outback so I know the EJ25's issues, mine blew up like plenty of others did.
McLovin80
McLovin80
Thomas
Greensboro, NC, USA
I thought it looked a bit too easy of an install for an AOS. I like how they consider it a performance part versus offering it as standard part of the engine.
The part is like an "easy button" for the average Bronco owner. Just have to remember to check it.
