Up fitter switches bronco outerbanks
rolando5425
rolando
los angeles
So I bought my bronco from a dealership and I didn’t order it so when I bought it afterwards I realized there were no upfitter switches I see where they capped off the wires and from my understanding I just need the switches and the fuse box but my question is will I need the harness as well to complete the swap
adam1991
VW GTI (2)
yes you'll need the harness.
Search here, you'll find a guy who did it complete with video. It's straightforward.
Dan-O
Dan
Fountain Hills, AZ
Many posts on this forum explaining all the options and needs to do what your asking. Step by step, vids, pics etc…. Just search this forum
“installing upfitter switches”. Some say you may need new harness others say not, adding to existing fuse block or replacing with upgraded fuse block etc…
adam1991
VW GTI (2)
I guess we should ask, what year OBX? I presume from what you say that it's not a 2025, but we should be clear. 2021-2024, you can add the switches plus a harness plus a fuse box and you're good to go. 2025, no upfitter switches, no wires in the engine compartment, you're stuck with Becky's sunglasses holder up there.
Msell71
Stilwell, OK
2023 Bronco
Real easy to add. You just have to pony up a small bucket of cash! Bought the parts, followed the vid mentioned above and it worked perfect.
Don Bouse
Edwardsville, Il
I've seen a rew videos recently where Garmin (I THINK) Makes a module that bolts up right next to your factory fuse block. You wire your accessories to that. It Bluetooths to your entertainment screen through your phone so you can switch your auxiliaries from your screen.
adam1991
VW GTI (2)
rolando5425
rolando
los angeles
Okay now that’s badass
