Turn off TPMS when you air down?
sliwa
Matthew
Ford Focus
Can you turn off the TPMS sensor when you air down? My last off road capable vehicle was an 84 Bronco, and TPMS wasn’t a thing.
Shabakuza
Jeremy
2016 STi // 2018 F-150
Been wondering the same thing. I hope it just shows the actual pressure values instead of lighting up the dash so I can monitor pressures when off road.
FourHorses
Four Ford Horses and an Expedition
Assuming it is like other Fords, yes it has a real time monitoring. and it is additionally viewable in the FordPass app.
I believe when the TPMS monitor alert comes on, you get a service light that remains a constant, but also a confirmation the "event" has occurred that you can accept/deny off of your main cluster display.
Megawatt
JO
Where the asphalt melts in the Summer
Lifted Rubicon usually off-road.
In my Jeep the TPMS always reads the instantaneous air pressure. When I air down the visual alarm comes in but I can still reads the individual pressures. I leave the display to air pressure when wheeling to let me see if I am get a flat. I also have a AEV pro cal that connects to the OBD port. You can use this to turn off the TPMS but then it reads 0 pressure so I never run it that way.
When I air down to 18 psi the TPMS alarms once, I acknowledge it and continue to read air pressures. Hopefully the Bronco version works similar.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I have an aftermarket programmer for my Jeep that allows you to set the TPMS alarm threshold to whatever value you'd like... If similar functionality isn't baked into the user options on the Bronco, my hope is that the aftermarket will eventually find a solution.
wjfawb0 [hacked account]
Tennessee
2015 Jeep Wrangler JKR
I have a low option rubicon without the EVIC (no pressure readings at all), and I use the AEV procal to disable TPMS (diagnostic mode) when running wheels without TPMS sensors. If I have wheels on that have TPMS sensors I leave the system activated. I just get the deflated tire warning the whole time I'm offroad and aired down.
sliwa
sliwa
Matthew
Ford Focus
How about don’t be a dick. Either answer a question if you’re able or keep on scrolling... ?‍♂
Headsong
And from what my mechanic told me, it's NOT a low pressure warning at all. It's about when the tires aren't the same. So if you drop them all down, it shouldn't alert.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I was hoping that if you went into any of the off road modes, it would disable the low pressure alert and just monitor. My current Ford does monitor in real time and will warn low pressure, one tire or all tires. I know some people don’t mind warning lights, but I hate when a warning light is on without being able to “fix” the issue. It would definitely make my time aired down less enjoyable.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
it's a good question. on my wife's lexus, the TPMS warning locks out the dashboard display between the speedo and the tachometer from displaying anything else. it also shutdowns the
abs.
MrJoe
Southern Maryland
'73 Bronco (sold), '99 Ram, '08 Explorer, '16 CMax
My 2016 Ford sends an audible and visual that can be ignored. Changes dash color to yellow, but everything still functions. Would be cool to have an offroad feature...
sliwa
sliwa
Matthew
Ford Focus
This would be an excellent feature! Its probably something that could be done by Ford as software update down the road?
