Turbo boost lost
Aaron james
Aaron
New york
2022 ford bronco badlands 4 door
Hi I have a 2.7 badlands and experienced that the turbo isn’t holding long enough any solution or idea what if is
CarGuy
New Jersey
2023 Ford Bronco
What do you mean by isn’t holding long enough? No boost, boost but no power, etc.?
Aaron james
Aaron james
Aaron
New york
It’s like a power but barely any boost being pushed out
Aaron james
Aaron james
Aaron
New york
I recently just switched my axle back back to my stock exaust
Ducati1098
No check engine light?
CarGuy
New Jersey
2023 Ford Bronco
If no boost, you may have a bad (open) blow off valve. I believe they are electronically controlled on the Bronco.
CarGuy
New Jersey
2023 Ford Bronco
Lots of moving parts with the turbo setup. Will be hard to diagnose with limited info.
Dmorty217
Derek
Venice FL
Camery
Any codes being thrown? Could be BOV, wastegate or a loose connection
Gramd
Graham
Airdrie, Alberta
2022 Bronco, 66 Chevy ll
What does your boost gauge say? Just zero?
Aaron james
Aaron james
Aaron
New york
Aaron james
Aaron james
Aaron
New york
As I accelerate it slowly goes down
where would I have to check for loose connections
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Is this your first turbocharged vehicle? Your video appears to be pretty normal, you aren’t really stepping into it and the boost comes down as expected as you approach a cruising speed.
thesocalexplorer
Southern California
Try sport / baja mode (in 2HI), and/or giving it more throttle. Your video looks pretty normal for a turbo vehicle.
