Tricky Dick's Dirty Bronco
Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Something appears to have gone wrong. I'm at 27" from hub to fender up front and 25" in the back. Almost no droop left in front. The winch alone isn't going to drop it enough so tomorrow I'm going to try compressing the coils while installed and see if I can get enough slack to drop the C clip down to the next groove.
I have the V6 Sasquatch coils for the rear too and may need to install them but IDK if they'll fit on the BL shocks.
Ford Bronco Tricky Dick's Dirty Bronco PXL_20230212_004059164
kodiakisland
Arkansas
Just move to Carolina and you’re golden.
I think you need to raise the rear more, regardless of what you do up front.
Just for reference, I get to 29.75 inches at full droop. Is your sway bar connected?
Dmorty217
Derek
Venice FL
Camery
Let's see some tire measurements! My 12.5s are 9.5" wide at contacting tread and right at 12.5" carcass width.
Thats a great IPA you have there
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Are those 4 door V6 springs? Looks like you netted 2" from just the coil swap.
Left over snow wheeling beer 🍻 figured I needed a reward for doing my yard chores.
Tricky Dick
Dick
PNW
They are. That did not work as intended. But I think adding the winch and moving to the 1.3" lift groove should get me to where I want to be.
I drove around the block and hit a few potholes and they did not feel harsh.
Tricky Dick
Dick
PNW
Ended up all the way down to the 0 lift groove to get to 26" from hub to fender.
@kodiakisland do you recall your pre-lift hub to fender measurement?
I'm drooping at 28.5, no swaybar.
Tricky Dick
Dick
PNW
I'm getting way too good at this. 20 minutes from tire on the ground, coilover out, adjusted, installed, tire on the ground. About to take it around the block and cycle the suspension a bit.
kodiakisland
Arkansas
24 3/8 on the front and 25 rear with the Badlands Bilsteins I think.
I never measured the droop with the Bilsteins.
Tricky Dick
Dick
PNW
None of this adds up. After the drive I'm sitting back at 24" in front and it took a 1.25" spacer to get to 25" in the back. It looks really good though with 35s and is about 2" higher than stock, judging by fender gap.
So I'm going to drop them out again, and go back to the 1.3" groove.
kodiakisland
Arkansas
None of this adds up. After the drive I'm sitting back at 24" in front and it took a 1.25" spacer to get to 25" in the back. It looks really good though and is about 2" higher than stock, judging by fender gap.
So I finally found some numbers written down in the garage. Have no idea if this was Hitachi or Bilsteins, but I think Bilsteins. 23 3/8 and 24. Most likely Bilstein numbers as I think the Hitachis were in the 22 inch range up front.
Tricky Dick
Dick
PNW
That makes sense. I wish I had taken measurements before tearing it apart.
Bikeric
Tulsa
2022 Badlands LUX on 37's
I just measured mine and got 25.5” front and 26” rear, but I’m parked nose down on my slanted driveway.
My measurements were done from center of hub to metal fender plastic flare line, then subtract 1”. 🤷‍♂️
kodiakisland
Arkansas
Why subtract an inch?
Bikeric
Tulsa
If I removed the plastic flare, I would be measuring to the bottom of the fender roll. I just figured that’s what was meant so I subtracted an inch. Otherwise I would be at 26.5” and 27”, and that can’t be right with non-Sas springs on non-Sas shocks. I’ve only got the perch collar lift in rear.
Status
