Transfer Case Technical Discussion
Yamapro
William
21 Bronco
I still wonder how you got codes for all 4? I find it hard to believe you damaged all 4 of them at the same time? Did you ever figure out which one was the bad one? and were the other codes set in error? I think there's still alot of room to improve this software. But hey, that's why we bring this stuff up right?
That’s the problem, they all check out ok now. No damage whatsoever that I or the dealership could find. They looked it over and just gave me the truck back.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
That's gotta be a software bug then...some combination of wheelspin, turning, etc that makes the wss's read something the computer doesn't understand. I haven't experienced it yet, but I believe you guys that say you have!
Yamapro
William
21 Bronco
I believe it’s software as well but a fix is desperately needed as this code left me virtually stranded. I really lucked up and had some side by sides winch me up the last big obstacle and I was able to force my way over everything else. It was a tough blow because I went from overly confident in the truck to questioning if it’s safe to trail ride in. This had the potential to leave me, and my family, stranded overnight. I was on this trail 9.5 hours and only saw these 4 side by sides all day.
orion
orion
Jeremy
17' F-250, 17' Explorer
You should have an OBDII code reader and try to clear the codes next time. I always have one with me, whether it be Forscan Lite or my dedicated OBD scanner. I bet you tripped them up and through a code yet everything was fine. Sometimes codes will clear themselves but need time/miles to figure out all is well. You could do that right then and there.
Bmadda
Wisconsin USA
Did you try disconnecting and reconnecting the battery? That should clear the codes if it's a glitch, or like @orion said, a cheap portable obd tool. I used to have one that Bluetoothed to my phone. Somebody borrowed it, and they need it more than me I guess!
Yamapro
William
21 Bronco
Is a “FORScan Light” what you would recommend?
Felix808
SRV CA
Good idea guys. (y)
orion
orion
Jeremy
I've yet to have to clear a code since getting Forscan, but yeah, it should work.
I3lackRose
Justin
Ohio
is there a TSB for 4A controller module replacement? I read sometimes they weren't disengaging as intended. I complained about the 4A seeming like its always engaed on front, dealer told me 4A isnt for pavement to which i had to argue yes it is. Its 4 advanced 4x4 AWD. They basically ignored me asking them about how i felt it was super noisy. On top of this im also having 7 speed manual transmission noises and last night she grinded in 2nd for no reason while already in gear.. No reliable fix for that yet from FORD..... :0
Dcook
Davon
Aurora Colorado
Jeep renegade trailhawk
4A is an encoder motor also, it's mounted on the front of the case instead of the rear. No way you could get vise grips in there, but looks like the right allen socket could do it. W/that motor not mounted tho, idk what keeps the linkage from vibrating into a different position, possibly neutral, wouldn't be something I'd wana do on the trail unless totally out of options. The part time xfer case looks way easier...here's pics, 1st the 4A:
Now the part time case. Looks like you could shift it w/a screwdriver, but how to keep it locked in position? Might be a strong enough detent to hold it in each position, but I doubt it!
any chance you could show me where the tcase range sensor is on our advanced tcase? Is it also called the position solenoid??
Ducati1098
It’s on top near the rear.
Ford Bronco Transfer Case Technical Discussion IMG_4016
Disconnect the transfer case range sensor connector and detach the wiring harness retainer clip from the transfer case.
Remove the transfer case range sensor retainers and remove the transfer case range sensor cover.
Remove the transfer case range sensor.
Dcook
Davon
Aurora Colorado
Awesome thank you! Any chance you have the ability to get the part number?
Ducati1098
MB3Z-7E440-A
You’ll probably need to lower the transfer case to get at it.
SierraBronco
Regarding the transfer case. When they do comparisons like that they are being just speaking to their group. I deal with people often saying Amazon Redshift is just as good as google BigQuery, but all that shows is their bias.
You will not get a manual transfer case in any current generation vehicles because the consumer won't accept it. That we got a manual transmission is a fluke. Down the road, we will have to bring a tablet computer with us as recovery gear. We'll plug it in and order the diffs to lock, the transfer case to engage, the power steering to work, or the throttle to work. All so we can limp back to civilization.
I know I’m bringing an old thread back to life. Spare me the forum comments of “this is an old thread. Start a new one” or “why didn’t you just do a search”
Just doing a deep dive into the transfer case and some recent issues we were having. And we literally had our laptop out with Forscan to get things going again.
orion
orion
Jeremy
What did you have to do in forscan and what was the error/codes you were getting? It might help others in the future!
