Transfer Case Manufacturer?
dgorsett
colorado
F250, Mustang, Explorer
colintrax
Georgia
Chevy Colorado, Ford Explorer, KTM 890 ADV
With that kind of info, do you know the manufacturer?
I don't like the idea of clutches, because like the Bronco Sport or other "Intelligent" 4WD systems of Ford, they overheat in sand and have to be cooled. I'd rather have a mechanical split.
These style have been used as far back as the 90s and are very reliable. The clutches dont slip like that. They truly lock.
AcesandEights
Ace!
Oregon
DR650
My old Bronco II's and Explorers had 2.72's and they were Borg-Warner, 1345's?? I think.
Yeah, thanks, I saw that later, that BW offered t-cases in 2.72:1
AcesandEights
Ace!
Oregon
DR650
What t-case is it, and how do you know how they work if you don't know what t-case it is? I'm not being argumentative, just asking for the model/specs.
Felix808
SRV CA
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Good article. I was concerned when I heard the xfer case had a clutch, but hopefully it is modeled after this xfer case that has both a clutch and a lock.
I try not to be to confident in my answers, because there is sometimes conflicting information. But my best educated guess, it's the same t-case as the F-150 Raptor. I also thought that about the transmission (10R80 vs. 60) and looks like it will end up being different, so can't be sure until it's released.
Felix808
SRV CA
The real question is.........
Will an Atlas twin stick transfer case be able to fit and work in the Bronco?
Easily, they are pretty compact heavy but compact. Loved my 5.0 Atlas in my XJ put me at 80:1 :cool:
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
I was thinking more of the layout in the cab. There's the GOAT selection knob to work around. Not sure where you'd put 3 extra levers.
Felix808
SRV CA
It would only be 2 extra levers. You can get extended shifters & torch bend them through the side of the tranny tunnel / center console if you had to. ;)
Edit: There are also cable shifters for the Atlas as well.
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
Pretty sure the twin stick has 3 levers. 2 for the front and rear differentials and one for the gear ratio selector.
Yes, they have cables, but those cables are connected to the levers in the cab.
I'm talking about the 4sp Atlas.
Felix808
SRV CA
Nope, 1 stick for each axle F&R. H-N-L are on each stick. 3rd stick would be for a manual transmission, but the Atlas only has 2 shifters.
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
How do you Select the different ratios (2.72/4.3/8 or 11.7) then?
