Trailrax TRMR installed
Oly_Bronco
WA
I got my @TrailRax TRMR installed yesterday and it is everything I was hoping for. First let me say that @TrailRax does an outstanding job packing the product for shipping. I originally thought I ordered the wind deflector with the light bar cutout but later realized I didn't. I think it will work out for now because I am still a few weeks away from getting my @Baja Designs 40" S8 light bar with the Blaze Off-Road Back Bone Wiring harness to connect to my Garmin PowerSwitch so now I don't have to wait. I did also end up ordering the wind deflector with the cutout so I will be ready when everything else comes.
Ford Bronco Trailrax TRMR installed IMG_0707
Ford Bronco Trailrax TRMR installed IMG_0708
Ford Bronco Trailrax TRMR installed IMG_0709
Ford Bronco Trailrax TRMR installed IMG_0710
Oly_Bronco
Oly_Bronco
WA
Added my Krazy Beaver shovel, my axe and my Rotopax water storage.
Ford Bronco Trailrax TRMR installed IMG_0720
Ford Bronco Trailrax TRMR installed IMG_0719
Oly_Bronco
Oly_Bronco
WA
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
@TrailRax any concerns about adding a 5lb propane tank mount to the Pak Rax using something like the propane tank mount from American Adventure Lab?
https://americanadventurelab.com/product/lightweight-5lb-propane-tank-mount/
That or Power tank makes a great mount. As long as you are mounting near the pak rax support arms it will be a strong place to put it but keep in mind the added width you will be putting on your Bronco with a 5lb propane tank. It is not as slim as a 2/4 gallon rotopax.
Oly_Bronco
Oly_Bronco
WA
The width is a concern I have. I may find an alternative for the propane and go with my original plan of adding a 3 gallon rotopax for additional fuel on the water side. Any plans on coming out with a light bracket for something like the @Baja Designs rock light that can be mounted to the side rail of the TRMR?
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
Yep, definitely in the plans. We are working with a few different brands with rock lights to make sure the mount is as universal with a multitude of rock lights as possible.
Oly_Bronco
Oly_Bronco
WA
Finally got my @Baja Designs 40” S8 light bar and also added amber Heretic Designs rock lights to their 45 degree mounts for some scene lights.
Ford Bronco Trailrax TRMR installed IMG_0773
Ford Bronco Trailrax TRMR installed IMG_0774
Ford Bronco Trailrax TRMR installed IMG_0768
Baja Designs
San Marcos
Lp4s and S8 are looking good! Such a clean setup (y)
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
Oly_Bronco
Oly_Bronco
WA
Best,
I also have 3x LP6 on my bumper along with a pair of SAE, driving combo and wide cornering squadrons.
Ford Bronco Trailrax TRMR installed IMG_0778
Oly_Bronco
Oly_Bronco
WA
Anybody looking to add a light bar, scene lights and chase lights to your @TrailRax TRMR, I would recommend looking into the Blaze Offroad backbone harness.
https://blazeoffroad.com/collections/2021-bronco/products/back-bone-wiring-harness-roof-rack
It allows you to run one harness down the windshield which has 4 switch wires and one ground that I connect to my Garmin PowerSwitch. The harness then connects pigtails for your light bar, scene lights and chase lights on the roof. So for my setup I have a pigtail for my @Baja Designs S8 that has 2 switch wires 1 for main light and 1 for backlight. I then have a pigtail for my pair of Heretic Studios rock lights which uses 1 switch and I will eventually have 1 for a pair of chase lights which will also use 1 switch. You can then use that Garmin PowerSwitch app on your phone or via Apple CarPlay to control your lights
Ford Bronco Trailrax TRMR installed IMG_0779
There are two control inputs on the Garmin PowerSwitch which I have one connected to my Aux 1 switch that will turn on both my @Baja Designs LP6 and S8 light bar when I turn on Aux 1. The other control input has a @SPVPARTS headlight harness that provides power to my backlights so when the headlights go on any of my lights with a backlight will turn on.
https://specialtyperformanceparts.c...kers-spv-harness-system-works-w-many-vehicles
Oly_Bronco
Oly_Bronco
WA
Added a 102L case from 23zero.
Ford Bronco Trailrax TRMR installed IMG_0780
Oly_Bronco
Oly_Bronco
WA
Oly_Bronco
Oly_Bronco
WA
Moved my traction boards from the very front because when it rained I found that it keep water on the boards and would dump water inside if the window was down.
Ford Bronco Trailrax TRMR installed IMG_1021
Ford Bronco Trailrax TRMR installed IMG_1023
CalvinT
Calvin
Phoenix, AZ
Oly_Bronco
Oly_Bronco
WA
