TrailRax TRMR Hardtop Removal Video?
Brad Fx
U.S.A
Jeep Commander
Does anyone have a video of removing the front and mid roof panels on a 4dr with the TrailRax TRMR rack? I want to see how easy it is to get the panels off, especially the middle panel.
I checked with TrailRax; they don’t currently have a Bronco to demo this, but maybe soon.
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
I didn't think to make a video, but I did briefly remove the front 3 panels with the TrailRax installed today. It's actually a little more difficult than it otherwise would be with my setup, because I have a JTop bimini installed as well. Makes maneuvering the panels more challenging when you can't easily manipulate them from inside.
Front two panels were easy enough. Just slowly slide them out from the sides, and there's plenty of room.
Mid panel was more challenging. There's less room as you have to lift one side over the bracket that it clips to (Just behind the front panels). I think the issue was largely due to my having the Jtop. It's presence means the bracket is just a tiny bit higher, which reduces the clearance even more. And it definitely makes lifting the panel out more difficult, even without a rack installed.
I was still able to remove the panel by myself in 5-6 minutes. Would probably come off in about 2 if you have a second pair of hands.
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
We pick up our Bronco this week, we should have a video within a few weeks following it. Stay tuned!
