Trailrax Pakrax snowboard mount installed
Hazard
Kevin
Nissan 350z, Mitsubishi Lancer, Range Rover LR3
Hey guys, I was approached by a few people already over on Instagram (@ohhhkevingee) and was told to make a post as it may be useful to some in this forum. Hope this helps those of you that have been looking for a board mounting solution.
I have utilized Trailrax pakrax mount to carry my boards, I have driven with this setup several times already over the course of this snowboard season; as close as Big bear roughly 150 miles round trip and as far as Utah, (1200 mile round trip). I’ve had no issues at all.
My mpg on avg without boards is between 18-20 . With the boards I avg 16-18.
Pretty straightforward mod, we used a Yakima Big powderhound mount and modified its mounting points to meet with the pak rax pre drilled holes.
So far I love this setup. If I only carry two boards which is how I have it majority of the time. Takes me less than 30 seconds to do it on my own. 4 boards, same time but with two people.
I do believe any ski mount would work for this, in my case to achieve a flush look and cause less drag, I did remove the pak rax panel as well.
This may not be a solution for everyone but hope this does help!
Ford Bronco Trailrax Pakrax snowboard mount installed 40506361-5A34-4402-861B-06463ADC845E
Ford Bronco Trailrax Pakrax snowboard mount installed 55EB75E9-84E6-4CA0-80B7-B08A40527904
Ford Bronco Trailrax Pakrax snowboard mount installed 2EF4288A-318E-4607-A79B-CAD199F2CF85
Ford Bronco Trailrax Pakrax snowboard mount installed CBC4BA34-20AC-4128-BAFD-F6F93EC10758
Ford Bronco Trailrax Pakrax snowboard mount installed D6C171C6-43D5-4982-949A-361A6B585D38
Ford Bronco Trailrax Pakrax snowboard mount installed FA737AE3-E9C6-447A-A881-8CEDF0388A97
Ford Bronco Trailrax Pakrax snowboard mount installed F4BEF47C-C852-43F5-864B-768646019720
Ford Bronco Trailrax Pakrax snowboard mount installed 4BDA7B37-1743-47E1-9603-AB717079C2F7
Ford Bronco Trailrax Pakrax snowboard mount installed 987E352D-A889-4EBD-86A3-4CA4C3A75FC4
KABQ
Aaron
Albuquerque, NM
That's awesome. I can see that working well for fishing rods as well.
Hazard
Hazard
Kevin
Definitely! I was actually going to originally use the smaller Rhino rack mount which doubles as a fishing rod holder but for my purpose it would not have worked out since it is a lot smaller but we did measure out the dimensions for that one and it does line up perfectly as well! Just went with a larger mount in my use.
BRKOBILLY2
William
Long Island, NY
Ford Explorer
That is a great idea. Love the ingenuity!!! I was toying with the Trailrax half rack as I don't need to have big boxes, tents, or other gear on top. I was just worried the bars were only about 21 inches apart and the specs for snowboard/ski rack is to be at 26 inches. But every company needs to put that conservative measurement as a CYA. Do the boards rattle much due to the overhang? I ride a 156 cm which would mean about 2 ft on each side +/-. Also so much easier than getting on top of the rig.
Hazard
Hazard
Kevin
No rattle sound coming from them at all. They do have a slight wiggle from wind resistance but they do not make contact with the doors window or
Hardtop
BRKOBILLY2
William
Long Island, NY
Ford Explorer
That is great thank you. Think this will be my winter set up!
Hazard
Hazard
Kevin
That’s good to hear! And for reference that I forgot to include the boards I have carried range between 152-161 and they all fit with no issues for the bindings or possible contact points. :)
XmasLightsBronco
Ryan
Anaheim, CA
This mod just jumped to top of the list. Thank you.
