Trailrax accessory mounting questions.
Doug_life
Oregon
23 wt, 78 bronco
I ordered a set of handles and a rotopax mount. There are no install instructions (rotopax has generic instructions)
The handles came with 4 bolts total for both handles. 2 per side.
With 2 bolts, there is a decent amount of flex on the handle when weight is applied.
Is the handle supposed to mount to the crossbar bolts? Then two bolts to the other side?
Also, i can only get the rotopax mount to line up with one row of slots. So it can only be mounted by 2 bolts. Anyone have suggestions?
Bronco_montana
NV
You don’t need to use the rotopax round plates. Just the 2 bolts. Much cleaner looking too.
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
can you just buy this or do you have to buy the whole setup and only use the 2bolts?
Bronco_montana
NV
All the rotopax mount kits I’ve seen come with the extra plates.
