Mounting Roam Arc 270 to Trailrax
ChefBoris
Seattle
2022 Bronco
Hey y'all.
I need your advice. I am mounting an Arc270 driver side awning to my Trailrax on my '22 4dr Outer Banks. I've machined the Trailrax braces to fit the Roam M8 bolts. However, there's a decent gap between the brace and awning.
I've seen these as part of setups all over this and other forums. But I'm stumped on how to ensure that I mount this securely.
Do I need washers to make up the gap? Should I get longer bolts? I know dumb questions. But help would be appreciated.
First pic shows the the bolts may be to short. 2nd shows the gap.
Thoughts?
Ford Bronco Mounting Roam Arc 270 to Trailrax 1000001164
Ford Bronco Mounting Roam Arc 270 to Trailrax 1000001165
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
You definitely want some spacers in there if you can’t get the bracket flat against the awning. There will be a lot of movement without it which could cause the nuts to come loose or deformation to the bolts.
4Rhino
Ray
Woodstock, GA
2022 Bronco
Hey y'all.
Thoughts?
What did you end up doing? I am doing this same install next week. Thanks!
