Trailrax Pak Rax install without removing top?
Mikem1025
San Antonio
2023 Bronco
Anyone ever install the pak rax without taking the top off? Looking for some idea's.
CalvinT
Calvin
Phoenix, AZ
Why look for misery? It's probably possible, but more work unless you don't have someone to help you take the back section off.
Dr Dan
Dan
New York
24 Bronco
I just installed mine two weeks ago so the process is pretty fresh in my head. I can't think of a way to get the lower brackets on that the pack rax bolts into without taking the rear clam shell off. There are bolts that need to be exposed which are completely covered by the roof. Once off, install is less than 5 minutes. No neighbor you could bribe with a beer?
Mikem1025
Mikem1025
San Antonio
2023 Bronco
Everyone is about 20-30 years older than me, I'm 46. I'll figure it out.
CalvinT
Calvin
Phoenix, AZ
It's been a while since I installed mine, but you may be able to put blocks under each side of the rear section to give you room to work to install the rear brackets. It will be fiddelly but with patience I think it can be done. Just make sure you don't tighten the bolts one one side until you have the bolts started on the other.
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
I just loosened the bolts on the front of the rack, removed the cab bolts, and jacked my roof up a couple inches using these...
WORKPRO Cabinet Jack Support... https://www.amazon.com/dp/B0CJTJ2F1W?ref=ppx_pop_mob_ap_share
Oh, I took the top front panels off, too. I think that's what I did!? Man, sucks getting old!
4dtrkman
Russ
Kingsport TN
F150 / Edge
When I installed mine my buddy lifted it and I put blocks in then installed it. Then lifted it pulled blocks and set it back on the pins. Should be able to get some help setting the blocks while you lift it.
Ford Bronco Trailrax Pak Rax install without removing top? 1IZzO_c6SOOzPqs3DJD-WQ
CalvinT
Calvin
Phoenix, AZ
ThunderFlash
Doug
Washington
It's better than the alternative.
Not sure about that. I just had my mother in law staying with us for the last 9 days while she recovers. Woof. I'm hopeful today is liberation day.
