Trailer hitch plug receptacle
quickstep192
chas
Maryland
Bronco Black Diamond
I’m looking to add a hitch to my 2024 Black Diamond
It looks like it’s pre-wired; there’s what looks like a connector protected inside a sheet metal bracket that held in by bolts far longer than they need to be for the job.
Anyway, do I need to buy a bracket with a receptacle for the trailer connector which I assume the pre-wired connector plugs in to? Assuming so, can someone help by telling me what that part is called and maybe where to get it?
Thanks for any help.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
That’s a bummer because of the cost, but saved me from possibly getting into a pickle. Thanks.
If you are going to be towing a trailer with brakes you will also need to install the in cab trailer brake controller. Also a Ford part number made by Redarc. It's all plug and play except for the mounting of the controller knob. Even if you order the tow package, you don't get the brake controller, which is a poor decision on Fords part. The whole tow package issue was poorly thought out.
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
No need for any programming if you are just going to use a 4-pin setup if you don't mind the backup alert. Total cost was $140 to add a Curt hitch & plug-n-play module for my '24
dgorsett
colorado
F250, Mustang, Explorer
There was a time when life was that simple...:(
Pipper99
Terry
Fort Worth, Texas
2024 Ford Bronco
I just need the trailer hitch receptacle to carry a bike rack. I was told buying and having one installed at U-Haul was a good option. Any thoughts?
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
It's pretty easy to do yourself. I bought a Curt hitch for less than $100 on Amazon, watched a YouTube video on removing the rear bumper and did the whole thing in under an hour. No need to do anything with wiring if you're just going to install the hitch to hold a bike rack.
box986
Paul
NNJ/NEPA
Yeah, hardest part is removing the 2 long bolts. I guess I should've just removed the bumper, but I cut em off with a grinding wheel.
box986
Paul
NNJ/NEPA
They do it everyday, so prob your best option if you're not gonna do it yourself. Maybe they will allow you to give them the hitch to install so you don't pay a markup on it. Here is the one that most say is the best aftermarket one: https://www.amazon.com/dp/B0B9NPWBQH?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_7
quickstep192
chas
Maryland
Now I’m a little confused- I thought you needed the module that goes inside to get power to the plug that’s in the bumper.
box986
Paul
NNJ/NEPA
Not if he's just needing the receiver for a bike mount & never plans on pulling a trailer
