Tow Shackle size.
North7
North Texas
SUV
JesseS
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Interesting, a 1 1/8 gap would normally be for a 1" pin, and you measures 7/8", that would make for a 1/4" of free space when mounted. Lots of rattle room, if this is the case will need nylon bushings on both sides for the tow hook up unless the tow bar adapters are a closer tolerance.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
The Throat opening is 1.25" and the Pin Diameter is .88 on 3/4" Screw Pin Anchor Shackle
- 4-3/4 Ton WLL.
I measured the shackle bracket width at 30mm(1.1811") which would leave .034" on each side.
If you look back a couple of posts at the front on picture that looks about right.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
North7
North Texas
SUV
Do you know what the inside length is needed to clear the mount? I’m guessing 2-4 inches?
Looking at the factory mounts, an inside lenght of 1 1/2" should clear, don't go over 1 3/4" to 2". HOWEVER, look at the inset cutout, a standard shackle may not fit or may look redneck.
Best to not let your cash burn a hole in your pocket and wait and see what the aftermarket determines will fit.
Ford Bronco Tow Shackle size. co-steel-bumper-stubby-bumper-pieces-sasquatch-
Ford Bronco Tow Shackle size. 8e6b9232-f89c-4c18-b5a5-eb059ca6db3d-jpeg
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Roger that, prob a better idea to wait than waste money on the wrong size shackle. Thanks man!
This is the one I got my eye on
https://www.amazon.com/Extreme-Max-...xtreme+Max+Shackle+7/8"&qid=1621272033&sr=8-5
North7
North Texas
SUV
https://www.amazon.com/Extreme-Max-3006-8255-2-BoatTector-Stainless/dp/B07JGGMKGZ/ref=sr_1_5?dchild=1&keywords=Extreme+Max+Shackle+7/8"&qid=1621272033&sr=8-5
Good to wait, those will not clear the inset, note what the factory ones look like. Keep your eye on Tasca Parts (a Ford dealer) for discounted genuine Ford parts.
https://www.tascaparts.com/search?search_str=Tow+hook
BroncoKong Jr.
Andrew
I think this picture confuses things since those shackles and mounts won't be available for MY21
edit: I found the specs on the ones @BroncoBoy22 posted and they will probably not work. I'd like to stress that rigging shackles are the way to go, unless it's just for looks. I will say that most likely any ¾" (⅞" pin) rigging bow shackle will fit on the factory mounts. Crosby, Van Beest, Columbus McKinnon, etc.
North7
North Texas
SUV
dgorsett
colorado
F250, Mustang, Explorer
Ah yes, the dreaded modular vs capable bumper saga. Many will get MY22 but we have to wait and see if Ford lets the Capable bumper see the light of day.
Capable Front Bumper vs Heavy-Duty Modular Bumper
I'm getting the standard bumper and have been thinking of installing shackle mounts and cutting away the 'boxes' to access making something resembling the 'Capable'.
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
A bit off topic but related to flat towing; what are your plans for brake assist and rear light hookups. I’m taking delivery this week on a Chinook B+ and eventually would like to flat tow the Bronco. We’re downsizing from an Airstream trailer so a flat towing virgin.
North7
North Texas
SUV
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Just bumping this thread up again - Anyone who has their Bronco already: Have you purchased some shackles for the modular front bumper? Curious what you ended up getting (brand/size)?
