Jimmiee
Reno, NV
Chevy Silverado
Nslsa66
Some awesome info here! I'm almost finished installing a 7 pin adapter with trailer brake controller. I just have the base Bronco, so install hasn't been super easy. Anyone happen to know the easiest way to access the brake switch signal wire for the controller?
flip
flip
Phil
IN
www.ruxerparts.com
Fords
I don't recall but is the harness not there behind the dash for a controller? It's a violet/white wire you can find in the C200 harness.
Ford Bronco Tow Package arrived - contents inside 1675791469677
Ford Bronco Tow Package arrived - contents inside 1675791505374
Ford Bronco Tow Package arrived - contents inside 1675791527066
Ford Bronco Tow Package arrived - contents inside 1675791751454
Nslsa66
Thanks for the info! Wasn't sure if the base had a harness or not, but I will give it a look!
Overlander22
jt
NorCal
2wd/2.7
Yazaki 7114-4121-02 big
Yazaki 7114-4111-02 small
If you need a couple LMK.
Belay my last. I read on and saw your website link...ordered there. Thanks!
21BroncoFlyer
Ben
Central, CA
1999 Land Rover Discovery
Not possible with FDRS. I spoke with some folks at Lumen who supply the current controller and they might be putting a complete kit together for later this year. Has to get approval from Ford but would be everything needed to install tow with braking.
@flip have you heard anything more on this? I had the brake controller installed at the dealer when I picked it up, and I’ve been sitting on the 4 pin wiring harness. I’d like to get full 7/4 functionality but wanted to see if there was a more holistic option yet.
flip
flip
Phil
IN
www.ruxerparts.com
Fords
I have not and since nothing has materialized yet, assume they mothballed it. He acted like the kit wouldn't be an issue for them but getting Ford to sign off on the integration portion would/could. Also, they could be running into the same semiconductor issue like everyone else and decide it wasn't worth the investment or time.
Overlander22
jt
NorCal
2wd/2.7
It's hot all of the time.
Sorry, novice here. Does this mean if we use
I would vote two, since there are the 30 and 40A available in the same connector, have one for future use.
Those 15A fuses are hard to find! Cost me close to $20 for a 5 pack shipped.
One or two fuses? I have abt 100 15A and would have to bump the price a bit.
I bought the package from your website but Curt says no more than a 10 Amp fuse. Appears 15 Amp is the lowest available for that fuse type. Think this is an issue for using the rear power?
flip
flip
Phil
IN
www.ruxerparts.com
Fords
The 15A should be fine. The connector that's being used for the power supply has 12V supplied to it even with the key off.
Fordtorino93
North Dakota
2019 ford f150
So I built my harness from the front back. I had another guy that reached out to me that couldn't get it to work. He purchased the entire harness that runs under the bronco to everything, from the connectors behind the drivers fender. I looked for mine they are available from ford but for the price I'll stick with mine I built.
Overlander22
jt
NorCal
2wd/2.7
After installing the Curt 4pin harness my 4pin to 7way adaptor isn't working. All tow vehicle tailights and turn signals are fine but running and brake lights, and turn signals to trailer are not. Power to trailer works. 4 to 7 adapter grounded at frame. I did sand prior to grounding. Any ideas?
Sains66
Evan
WA
66’ Ford Mustang
flip
flip
Phil
IN
www.ruxerparts.com
Fords
https://accessories.ford.com/products/trailer-hitch-wiring-harness-4-7-pin-by-lumen
@flip have you seen that this is on the market now? It looks like the controller and harness are finally being offered As a package from Lumen. I have held off on putting mine together hoping something like this would be available. Does anyone have experience/feedback on it?
Cool! Forgot when I spoke with the rep but they (Lumen) acted like it was an act of God to get anything approved to integrate with Ford's software. Looks like they finally got it done. I'll see if they're available and get a few ordered.
