Tow hitch onto Base model?
sootie007
Fl
GMC , Scion
Im in the same boat original poster .- base model ...Looks like 4 bolts....sure is a small piece in general .
Ford Bronco Tow hitch onto Base model? hitch
85_Ranger4x4
Iowa
1985 Ford Ranger
As long as the bumpers are the same... I am suddenly much less inclined to think that little thing is worth $600.
Its like $150 on most things so I figured it was some big elaborate assembly.
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
NotaVegetarian
Nota
Gone Hunting
1978 Bronco, 1979 Bronco, F250 Super Crew
Drop it off at my shop if you want it welding in. Your the customer your paying for it get it how you want it.
The Pope
1977 F250/2007 Mercury Mariner/2014 Infiniti Q60x/2011 Kawasaki C14
There will be Plug-N-Play Harnesses from the aftermarket. Just have to give the aftermarket a little bit of time.
Here's a link to Etrailer.com for a harness for the 2021 Ranger: https://www.etrailer.com/t1-2021_Ford_Ranger.htm?&Redirect=8
E-trailer rocks!!!
I spent less than 400 bucks for everything for my Nissan frontier which was all plug-and-play.
I made that statement back on Nov. 9th 2020. There have been some new information reviled since then, so it "might" not be this simple. We can only hope.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Yeah I've seen a few people report that there isn't a separate harness, the trailer wiring goes right into the main loom. I didn't look for myself when i had the chance so I can't confirm.
Southside_Ray
Ray
Iowa
2014 Ford Fusion
So perhaps order the trailer wiring kit that's in the accessory guide if we plan on getting an aftermarket hitch?
Tricky Dick
Dick
PNW
I would sure like to see some clarification at least. I've also seen it said that the accessory guide wiring is only a 4 pin harness instead of the 4/7.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
The wiring is my only worry. I will definitely want plug and play. The factory hitch just isn't what I was looking for. I hate to even type this, because it makes people crazy, but I will be looking for a "real" class III hitch as I will occasionally trailer my boat that will exceed the class II rating of the factory hitch.
HoosierDaddy
__ Eric
NW. Indiana
The only concern that I would have is the gearing unless you are getting the sasquatch.
Taking the tire sizes into account, the effective gear is basically the same across the board.
The biggest difference is the higher gearing of the auto or v6(3.73) vs the manual 4 (4.42)... assuming base 2-door.
Even at that, maxed at 3500 lbs, the 3.73s will be fine
Lakelife36
Ben
Interior of BC
Isn't that what the Ranger runs on similar size tires?
AZ_Liberty
2007 Expedition
I have towed a lot of 4 wire trailers over the decades, never actually towed one with a 7 pin or brake controller. So, I figure I will be perfectly adequately served with an aftermarket hitch and 4-pin harness. I also expect that will cost me under $150 from etrailer.
If I ever need to tow a trailer with electric brakes I can buy a brake controller for the wife's F-150
HoosierDaddy
__ Eric
NW. Indiana
I think that is correct.
I almost said that, but wasn't certain and didn't care to look it up.
