Torque Spec on Hard Top Latches?
The Bronc
MJ
Nashville, Tennessee
04 Xterra; 04 Element; 06 Sentra; 10 Rav4
I have one latch on the passenger center that will loosen to the point the corner raises and I can hear wind coming in as if the passenger window is cracked. The latch feels tight and I hear the “click” when it is engaged but I am wondering if the hex nut in the latch needs to be tightened. I am seeking the torque spec for the hex nut in the latch so that I do not over tighten. Thanks!
Dr Dan
Dan
New York
24 Bronco
It's low, only 12 Nm. You don't want to crack anything.
Onestepmore
Amos
Ballwin, MO
2023 Ford Bronco Badlands with Sasquatch
I'm not saying this will fix your problem, but I use the hand tightened Rockworx which work great and I have no air noise...just a thought...
The Bronc
The Bronc
MJ
The lose latch is on the passenger center panel and the rear.
CalvinT
Calvin
Phoenix, AZ
Somewhere on Bronco6G is a thread telling how to check and adjust panel alignment. Looks like I didn't mark it though. The thread was about what to check before making modifications to get rid of wind noise.
