- Joined
- Apr 9, 2021
- Threads
- 174
- Messages
- 8,965
- Reaction score
- 32,051
- Location
- British Columbia
- Website
- www.bronco6g.com
- Vehicle(s)
- 2024 Toyota Tundra TRD Pro
- Your Bronco Model
- Badlands
- Thread starter
- #16
One additional question: When you have the top off and on the Venture Pro, can you "lower" it and move it around your garage?I have a Badlands Sasq. The Venture works great w
I disassemble it when not in use, by separating the base from the top half, and then fold up the casters so it sits flat against a wall.
I have a Badlands Sasq, and I can have the hood high enough to park the Bronco under the raised cap (here are some pictures I took of it in the garage.... could have actually parked the Bronco closed to the lift but I had some blocks on the garage floor that I didn't more so I couldn't drive further forward).![]()
My thought is with my garage height I may need to park my Bronco outside, remove the top, but need to "lower" it (almost like I'm re-installing the top on the Bronco) to get it under my garage door and back in the garage - Where I could then raise it again for storage.
Hopefully that makes sense? I'm just curious if it wants to tip over or anything when you put it in the lower position but not actually placing it back on your Bronco.
Thanks!
