Top speed limiter AKA Governor
Weld3z
Ahmed
United Arab Emirates
Jeep
Please don't tell me 105 miles !!
Any idea, tyre sizes different between trims.
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
It will be under 120mph because most LT tires are only rated to 120.
wolfpackinva
Santiago
Doswell, VA
'17 Focus, '08 E350, '13 Tundra
My '16 Focus doesn't have a governor that I've found (124). My '08 E350 is set at 90.
bluesun68
Havasu
raptor, velar, f-type
My 6.2 Raptor is limited to 99 because of tires. You can buy tires rated higher, in the KO2 series. I guess they are rounder??? Or xray better? Speedo reads about 103 when the limiter kicks in.
zero_swagger
Ryan
phx
Alfa Romeo
Why do the American manufactures add governors? Every Chevy and Ford I have owned has had one. Yet all the foreign cars I own, nothing....
cal jammer
St Louis
Focus ST
My vw GLI had one at 140 If I remember correctly, did get it up to 145 on a slight downhill once.
Straight 6
Brad
Ca
BMW
W
You just have to go faster
The Germans mostly limit at 155 mph, a few are lower and some are unlimited
American cars generally have the governor because they put low speed rated tires on them BOOM FLIP FIRE DEATH
BroncoJeremie
Jeremie
Cedar city
2006 Ford F-150
They exist because not every tire can go 200mph, they will rip apart. Off-road type tires have very low speed rating typical cutting off on the 100mpg mark or at least around there. Plus if you plan on going 120 on 35s you are just crazy
brewdad
Alabama
2019 Ram
Wrangler Rubicon limited to 97 mph, all other Wrangler trims limited to 110 mph.
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
I'll fill you in on a little secret. It won't be long after the Bronco comes out that aftermarket tuners will begin to support them. I have an SCT tuner with custom 5star 93 octane tunes I use with my Ecoboost F150, which I hope will eventually be able to be paired with my Bronco through an update. You can disable both the speed and rev limiters through the tuner interface. Disclaimer: Using an aftermarket tune on a vehicle still under warranty will sometimes void the warranty if the dealership notices the changes on an OBD scan. Best not to use a tuner until the powertrain warranty has expired unless you don't care about the warranty. But, tuning an Ecoboost really wakes up the potential these engines have, if done within safe parameters from a reputable custom tune shop. Also stick below the speed ratings of your tires or you can possibly run into trouble.
AK SNO RIDER
Ty
Alaska
I love me a fast vehicle but the Bronco doesn't need to go any faster than 100. Because the correct tire for a Bronco is an MT and most are rated for 98.
crowdpleazer
Daniel
West Virginia
Ford Ranger, Honda Civic
It's shaped like a brick and has off road tires and suspension. 100 mph is plenty fast enough.
Aman
Aman
Northern NJ
My E46 M3 was limited to 155mph. Have bounced off it numerous times at road courses with long straightaways. :cool:
