Tire sizes base bronco build
M97
Ford Bronco Base
Hi all I have 4 door base with 30” tires if I upgrade to 33” tires and 17” rims will a notice a difference? Will it make it look bigger? Even though it’s not.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Not sure exactly what you mean by 'look bigger' but 33" tires are absolutely bigger than 30" tires, regardless of wheel size. Your truck will be 1.5" higher off the ground. You will notice a difference.
emkayw
mike
southern california
ford fusion
I agree with Budget Bronco. I put 33's on mine as well. It fills out the wells nicely with the 17" wheels, feels and looks taller.
RC Bronco
Kansas
You will 100% notice the change in stance. As stated above, it will sit 1.5” higher
M97
Ford Bronco Base
Thank you all
jrollo7
James
NY
Range Rover Sport
What adjustments need to be made like “leveling”? Lifting” odometer adjustment?
Csaldivar78
Caleb
Georgia
2019 ranger with a 2022 bronco on order
It definitely helps it not look like a mail truck 😂, I have 33’s and 20’s just to kinda help give you an idea.
Ford Bronco Tire sizes base bronco build 5C40B91E-8F2E-4BA8-8853-CA68E2D276C2
M97
Ford Bronco Base
I only know of speedometer calibration. No lift needed
Bronc N Roll
Newport Arkansas
2023 Bronco
Thank you all
Absolutely, I just took off 30” Ht with steelies found 17” badlands black powder coated wheels with 255/80/17 Falken Wildpeak 10ply. I now have 623 miles on my 23 2 door race red, 2.7. One road trip got 22.2 mostly Highway. Next tank 19.1 mostly town driving
Ford Bronco Tire sizes base bronco build IMG_6657
Ford Bronco Tire sizes base bronco build IMG_6685
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
IMHO 33" tires are perfect on the 2 door base. I went with the Everglades wheels and that pushes them out to the edge of the flares.
Arrowbear Rider
Marcus
Laguna Woods, Ca
Bronco, Triumph Thunderbird Commander 1700
What do you plan to do with your Bronco? Because any use in the dirt and you'll notice the difference, better handling and bigger rocks can be cleared. If only a street machine, you'll notice the difference in stance and handling due to putting more rubber to the road and your fuel economy will decrease a little, but not too much with that size, 35" from 30" change the MPG enough to notice.
