Tire size
Dmorty217
Derek
Venice FL
Camery
What’s the largest tire I can put on my factory wheels on my black diamond with these https://www.mishimoto.com/checkout/cart/
And not have rubbing without a lift? I have about 5” from factory height before the bronco won’t fit in my garage anymore which is a no go. Ideally I would like 35s but 285/75/17 would also be ok if that’s the route I have to go. I paid for the upgraded wheels from ford so having those with the brand new tires from the factory sitting in my garage taking up space while spending $4500+ for new wheels and tires I would like to avoid.
OhhhhhhSnap
Elan
CO
06 Pathfinder, 04 F150, 14 CRV. 22 BD Bronco
You linked the cart, not the actual product.
F OR D
BD Green Machine
a 1" level and 33s on the bd is the sweet spot imo
Mannym5
Manny
Huntington, NY
2022 Ford Bronco BD, 2016 BMW M2, 2001 Honda S2000
285/75 or 295/70 is the largest I've seen without requiring mods. I think some people may have squeezed sasquach sized tires(315/70) but at a minimum you will need to remove the crash bars and IMO they look overstuffed on the narrow rim.
To me 285/70 is the sweet spot for stock BD or BB wheels and that's what I will end up going for. There are also a lot more choices in this size.
A lot of the 285/75's and 295/70's that I have seen are E rated and very heavy/stiff. This is something else to keep in mind.
What size spacers did you go for? I also ordered Mishimoto Spacers in 1in. My black diamond should be here by the end of the month.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
I haven’t ordered the spacers yet since I was waiting to hear replies to this thread before ordering. I’m leaning towards the 2” though. My blend date is tomorrow and hope to have a delivery estimate by the end of the week/beginning of next. I know it’s coming by rail so I’m sure it will be a slow, painful wait.
F OR D
BD Green Machine
there's some good threads on this too, do some digging.
i'd note if you are 2 door look at a 1" level and 285/70/R17 KO2s. 2" lift may be a little much unless you are going bigger wheels. 4d i'd probably consider 2" level and 33-35's to help with the stance. 2d on 33s is perfect, 4d needs a little more imo.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
It’s a 4 door. My dealer tried to tell me $850 for a 2” lift installed (I provide the lift) which is crazy high IMO. Other places I have spoke with told me 3-4 hrs at $100-110 a hr. I guess the question is with the 2” lift and 2” spacers is that enough to prevent rubbing with 35s? I read different things here and can’t keep it all straight.
F OR D
BD Green Machine
all in the wheel offset.
+1 wheel offset gets you 35s no lift
35's on Black Diamond, No lift, No rub | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
2" you should be good
4WP Fender Deletes + 2” Level Kit + 35s on Bronco Black Diamond. | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
2+2 definitely good and will be poking out.
remember to get your speedo recalibrated. you will be 5-6mph under with 32-35s.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
How do you recalibrate the speedometer, forscan? That’s one thing I feel I’m way under qualified to use. I do like things you can do with it that I have read but it seems daunting.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
