PSI tire pressure on 35's?
JvKintheUSA
Everglades
Georgia
Everglades
I got the 35 inch factory tires and the recommended PSI is 39, which seems high (maybe to save gas?). I never had 35s, but the 33s on my Jeep, I ran at 34 PSI. What PSI do y'all run on your 35s?
jsoa
Jose
Delaware
2024 Bronco 4dr
my 35s came from the factory at 42 psi according to the sensors, I have yet to adjust them... sounds like I should
Baja Bronco
2Sun AZ
I run 34 / 35 psi in my 37s. 39 seems high, but tire psi is so subjective. Try some different pressures until youā€™re happy with the results. Whatever works!
Glade Runner
Everglades
VA
Yes
Everglades
Mine came from the factory at 46psi. I lowered them to 39, but havenā€™t changed them from there yet to compare.
swamp2
Do a chalk test. Someone posted one here for their Raptor that 35 psi looked solid, saved me 10 minutes...
BumbleBee
Qatar
Bronco Wildtrack 2022
I'm running my 35 at 38 psi, feel perfect and hot they go up to 40-41, so seems correct.
Tried at 35psi, feels nice and soft, but corners a bit too much.
Fordified1
Bob
Mid South Texas
ā€˜15 Mustang ecoboost, 4wd Excursion, ā€˜69 Mach 1
Iā€™m running 35 psi. 35x12.5 tire on a 9ā€ rim Havenā€™t done a chalk test yet.
Bugkillah
Keith
North Augusta, SC
Jeep Wrangler, Nissan 370Z Nismo, Nissan Frontier
I run 39 psi cold on 35ā€ Sasquatch tires, they warm up to 41 or 42. Feels good to me for the streets.
604Bronco
British Columbia
www.bronco6g.com
Iā€™m running my 35x12.5 on the OEM Sasquatch wheels at 40 PSI. I believe the tire says 50 PSI is where they ā€œshouldā€ be at.
AndGerry
Tomas
2012 GMC Acadia Denali
Door sticker on my 23 WT has 39 psi cold, but I thought it rode hard whenever it got warm at 43 psiā€¦ Iā€™m trying it at 35 psi and I think I like the ride better.
JvKintheUSA
JvKintheUSA
Everglades
Georgia
Everglades
Yeah, that's what I'm going to try
mjcutri
M
Upstate SC
2023 Bronco HE
I run 34-36 psi cold. Rides great!
Onestepmore
Amos
Ballwin, MO
2023 Ford Bronco Badlands with Sasquatch
Same as others...I've ran my 35's at 39psi and have 10k on them...they are wearing very nicely, so I'm sticking with the manufacturers specs
Mjasi3
Chicago
never inflate to what it says on the tire. that is just the tire manu max
userdude
Denton, TX
2023 2dr Badsquatch
I've run everything from 32 to 40 with the GY Territories. The higher the psi, the stiffer the ride on my 2dr BL Sas. 32 was a little to soft, I think 34-35 works best for me unless I'm on a long drive.
