Thinking of getting code scanner
Area51BS
Ron
Badlands non SAS 4dr 2.3
With warranty expiring. And hit or miss dealer work quality. Nevermind the cost. I think a decent code scanner might be worth investing in. Any recommendations? My Bronco has been pretty good. But it’s a matter of time if you follow the forum.
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
You may want to look at scanners that are compatible with FORScan. I have the OBDLink MX+ and it stays in my Bronco. You can do much more than just read trouble codes.
Same one I use with Forscan most of the time. Also works with the phone apps. Nice Bluetooth adapter
Just note it will not work with FDRS though, if you ever need that
TiKi-Bronco
Land O Lakes FL.
2024 Bronco
I used to use an XTOOLS D8 scan tool but now use the VDiag v70. It is great with the bluetooth dongle so I can walk around the vehicles or do live data reads while driving without a cord getting in the way.
KillerPenz
North East
I went with the VGate Vlinker. It's Bluetooth and works with ForScan Lite. I keep it in the glovebox and use it when I just want to see the code.
I also have the OBDlink EX for when I want to actually get use out of ForScan other than reading codes.
