- First Name
- Colby
- Joined
- Oct 4, 2021
- Threads
- 9
- Messages
- 935
- Reaction score
- 3,125
- Location
- MB
- Website
- www.cspencephoto.com
- Vehicle(s)
- 2022 Badlands 2DR
- Your Bronco Model
- Badlands
- Thread starter
- #1
Welcome, This is nothing more than a thread to track oil changes, mods and the occasional maintenance item.
The Boreal Badlands:
22 2DR Badlands, 2.3T, 7 Speed
Eruption Green
MGV, High Package, MIC, Capable Bumper, Tow Package, Optional Wheels
Current Thoughts:
PNW dreamin'
Current Issues:
MGV Cracking on Drivers Seat
Notable Threads:
Bears or Bust Trip Report
DD Hitch Pod Write Up
2DR Trail Cover Write Up
Pup and Peaks Trip Report
Maintenance Log:
First Hit to the Glass - 1,170kms
Lost a Bolt Down the Defroster Vent - 3,501kms
Windshield #2 - 22,000kms
Fog Light Wire Repair - 36,500kms
P061B/P2119 Codes/Limp Mode - 39,850kms
Motorcraft FA-2022 Engine Intake Air Filter - 40,400kms
U3001/U0401 Codes/Limp Mode - 41,300kms
Driver Seat Cable Fix - 43,580kms
Headlights Re-Aimed - 43,640kms
C103A Codes - 45,300kms
TSB 23-2006 - 45,774kms
Replaced FSD MB3Z-5482-C - 46,928kms
TSB 22-2371 - 48,124kms
Replaced Front MIC Panel Outer Seals M2DZ-9854382-A/B - 48,124kms
P008A/P00C6 - 50,685kms
Replaced Fuel Line MB3Z-9J280-B - 50,707kms
Windshield #3 - 58,098kms
New Adv. Transfercase - 58,177kms
Windshield Wipers M2DZ-17528-A - 60,070kms
Cabin Air Filter - FP93 - 60,150kms
Falken Wildpeak AT3W 285/70R17 - 66,985kms
Alignment - 68,151kms
Motorcraft FA-2022 Engine Intake Air Filter - 71,892kms
TSB 22-2371 (#2) - 76,360kms
Slave Cylinder MB3Z-7A564-C - 76,360kms
Windshield #4 - 79,422kms
Rear Brake Pads - 84,002kms
Vacuum Line MB3Z-2420-K - 92,683kms
Windshield #5 - 97,707kms
Motorcraft Spark Plugs SP-594 - 97,771kms
Motorcraft FA-2022 Engine Intake Air Filter - 97,771kms
Serviced Broken Wires for the FSD - 120,082kms
Serviced Broken Wires for Front Parking Sensor - 121,035kms
Serviced Broken Wire for Rear Parking Sensor - 129,385kms
Alignment - 131,570kms
Motorcraft FA-2022 Engine Intake Air Filter - 131,586kms
Cabin Air Filter - FP93 - 131,615kms
Nitto Terra Grappler G3 285/70R17 - 131,615kms
Passenger Mirror Assembly - 132,613kms
Cooper Discoverer Snow Claw Studded 285/70R17 - 145,855kms
Recall 25S49 (Replace Rear Camera) - 147,367kms
Recall 25S01 (Replace Rear Shock Absorber) - 148,919kms
OCI/Fluids Log:
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 4,048kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 20,342kms
Pennzoil Euro LX 0w-30 w/ FL-910S Filter - 30,363kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 40,400kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 50,960kms
Front Diff Fluid Change w/ Motorcraft® SAE 80W-90 Premium Rear Axle Lubricant - 50,960kms
Rear Diff Fluid Change w/ Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant - 50,960kms
T-Case Fluid Change w/ Motorcraft® MERCON® LV ATF - 50,960kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 60,018kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 71,177kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 79,446kms
Rear Diff Fluid Change w/ Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant - 84,255kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 92,471kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 97,865kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 110,236kms
MT88 Fluid Change w/ Motul DCTF - 121,035kms
Front/Rear Diff Fluid Change w/ Motul Gear 300 75w-90 - 121,035kms
T-Case Fluid Change w/ Motorcraft® MERCON® LV ATF - 121,035kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 121,035kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 132,570kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 143,958kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 152,282kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 158,563kms
Tire Mileage Log:
OEM BFG KO2's - 66,985kms
Falken Wildpeak AT3W 285/70R17 - 64,630kms
Mod Log:
MRT Hood Struts - 200Kms
MRT Trail Rated Turn Down Axleback - 200Kms
Mishimoto Catch Can - 200Kms
JCR Tailgate Table - 200Kms
IAG v1 OEM Rock Rail Steps - 200Kms
GCPA Hardtop T Bolts - 450Kms
Kicker 46CSC674 - 6 ¾" CS - 550kms
Kicker 47KSC404 - 4" KS - 550kms
Diode Dynamics SS5 Sport Combo Amber - 1,230kms
RekGen Trophy Standard Front Flaps - 1,230kms
BYB Picatinny Rail - 1,230kms
Assorted Molle Gear - 1,230kms
Diode Dynamics SS3 Max SAE Fog Amber - 3,000kms
OEM Aeroskin I - 3,000kms
Got Naked for the First Time - 3,500kms
RC Hidden Winch & Pro9500S - 3,800kms
Bartact Grab Handles/Molle Bags/Door Bags - 20,342kms
Hertz CX100 4" - 23,000kms
Diode Dynamics Hitchpod - 30,363kms
JCR Spare Tire Rack - 32,000kms
Suma Mirrors - 32,000kms
DIY Mishimoto Catch Can Drain - 34,500kms
RotoPax, Mount, Custom Spacer - 35,600kms
Oracle BRONCO - Black w/Amber - 36,500kms
Seat Back Protectors - 36,500kms
IAG v2 OEM Rock Rail Steps - 36,500kms
Baja Designs LP9 Amber Driving Combo w/ Capable Light Mount v1 - 36,500kms
Rough Country D-Rings - 40,400kms
MoarDoor 2.7 Auto Tow Spring Swap - 43,580kms
IAG Foot Pegs - 47,000kms
Trailgear Oasis Cover - 48,000kms
DIY Paint Correction - 50,960kms
Underground GFX - 50,960kms
Rough Country Hidden Winch & Pro9500S - 51,250kms
Powerbass XL-42SS - 56,985kms
IAG LED Interior Light Kit - 67,704kms
AuxBeam 8 Gang Switch RGB - 67,704kms
Baja Designs S8 40” - 67,704kms
Turbosmart VR19 DP BOV - 68,369kms
Diode Dynamics SSC1 Pro Flood Flushmount - 69,312kms
Diode Dynamics SSC2 Pro Combo Flushmount - 69,312kms
3W Liners Floor Mats - 69,350kms
Steeda Clutch Spring - 69,390kms
5% Sunstrip - 71,530kms
Ford Performance M220 Diff Cover - 84,255kms
Rockslide Engineering Roto Pax EZ Mount - 85,019kms
Plug N Play Harness - 85,200kms
Kicker Key 200.4 - 85,200kms
AudioControl LC2i Pro - 85,200kms
Hifonics Brutus 1200.1D - 85,200kms
Focal E30KX K2 - 85,200kms
Focal 1.1000 FPX - 86,121kms
Optima Yellowtop - 129,261kms
2x Pioneer TS Z10LS2, Custom Boxes and Internal Rack - 132,570kms
BDUSA Vent Tabs - 140,051kms
ModCrate Latch Plates and Bushings - 140,683kms
Suma Mirrors (warranty) - 149,985kms
Method 703 17x8.5 +35 Bronze
Future Mod List (in no particular order):
Items Ready to Install:
El Cheapo Rocklamps (one on each corner plus two under hood, cause the mall can always use more lighting)
Auxbeam Light Controller
Oracle Tail Lights
Front Brake Pads
Dashcam
On Order:
N/A
Bronco Hitch Accessories:
Camper - 2024: Axle upgraded to 3500lbs. 2025: Lighting replaced and rewired. Charging system revamped. Roof rack built with awning, cargo box, spare tire and solar shower. 2026: 24v converter, Starlink, redo interior switch panel
Wilco Hitchgate - converted from full-size spare tire carrier to a snowboard/ski carrier.
Kuat Sherpa 2.0 - Picked her up second hand, like new.
Recent Photo:
Eruption Green
Current Thoughts:
PNW dreamin'
Current Issues:
Notable Threads:
Maintenance Log:
OCI/Fluids Log:
Tire Mileage Log:
In: 152,282 Out: ---
Total: 14,269kms
Cooper Discoverer Snow Claw Studded 285/70R17In: 145,855 Out: 152,282
Total: 6,427kms
Mod Log:
RotoPax,
Oracle Tail Lights
Front Brake Pads
Dashcam
On Order:
N/A
Recent Photo:
