Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Welcome, This is nothing more than a thread to track oil changes, mods and the occasional maintenance item.
The Boreal Badlands:
22 2DR Badlands, 2.3T, 7 Speed
Eruption Green
MGV, High Package, MIC, Capable Bumper, Tow Package, Optional Wheels
Current Thoughts:
PNW dreamin'
Current Issues:
MGV Cracking on Drivers Seat
Notable Threads:
Bears or Bust Trip Report
DD Hitch Pod Write Up
2DR Trail Cover Write Up
Pup and Peaks Trip Report
Maintenance Log:
First Hit to the Glass - 1,170kms
Lost a Bolt Down the Defroster Vent - 3,501kms
Windshield #2 - 22,000kms
Fog Light Wire Repair - 36,500kms
P061B/P2119 Codes/Limp Mode - 39,850kms
Motorcraft FA-2022 Engine Intake Air Filter - 40,400kms
U3001/U0401 Codes/Limp Mode - 41,300kms
Driver Seat Cable Fix - 43,580kms
Headlights Re-Aimed - 43,640kms
C103A Codes - 45,300kms
TSB 23-2006 - 45,774kms
Replaced FSD MB3Z-5482-C - 46,928kms
TSB 22-2371 - 48,124kms
Replaced Front MIC Panel Outer Seals M2DZ-9854382-A/B - 48,124kms
P008A/P00C6 - 50,685kms
Replaced Fuel Line MB3Z-9J280-B - 50,707kms
Windshield #3 - 58,098kms
New Adv. Transfercase - 58,177kms
Windshield Wipers M2DZ-17528-A - 60,070kms
Cabin Air Filter - FP93 - 60,150kms
Falken Wildpeak AT3W 285/70R17 - 66,985kms
Alignment - 68,151kms
Motorcraft FA-2022 Engine Intake Air Filter - 71,892kms
TSB 22-2371 (#2) - 76,360kms
Slave Cylinder MB3Z-7A564-C - 76,360kms
Windshield #4 - 79,422kms
Rear Brake Pads - 84,002kms
Vacuum Line MB3Z-2420-K - 92,683kms
Windshield #5 - 97,707kms
Motorcraft Spark Plugs SP-594 - 97,771kms
Motorcraft FA-2022 Engine Intake Air Filter - 97,771kms
Serviced Broken Wires for the FSD - 120,082kms
Serviced Broken Wires for Front Parking Sensor - 121,035kms
Serviced Broken Wire for Rear Parking Sensor - 129,385kms
Alignment - 131,570kms
Motorcraft FA-2022 Engine Intake Air Filter - 131,586kms
Cabin Air Filter - FP93 - 131,615kms
Nitto Terra Grappler G3 285/70R17 - 131,615kms
Passenger Mirror Assembly - 132,613kms
Cooper Discoverer Snow Claw Studded 285/70R17 - 145,855kms
Recall 25S49 (Replace Rear Camera) - 147,367kms
Recall 25S01 (Replace Rear Shock Absorber) - 148,919kms
OCI/Fluids Log:
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 4,048kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 20,342kms
Pennzoil Euro LX 0w-30 w/ FL-910S Filter - 30,363kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 40,400kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 50,960kms
Front Diff Fluid Change w/ Motorcraft® SAE 80W-90 Premium Rear Axle Lubricant - 50,960kms
Rear Diff Fluid Change w/ Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant - 50,960kms
T-Case Fluid Change w/ Motorcraft® MERCON® LV ATF - 50,960kms
Pennzoil Platinum 5w-30 D1G2 w/ FL-910S Filter - 60,018kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 71,177kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 79,446kms
Rear Diff Fluid Change w/ Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant - 84,255kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 92,471kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 97,865kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 110,236kms
MT88 Fluid Change w/ Motul DCTF - 121,035kms
Front/Rear Diff Fluid Change w/ Motul Gear 300 75w-90 - 121,035kms
T-Case Fluid Change w/ Motorcraft® MERCON® LV ATF - 121,035kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 121,035kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 132,570kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 143,958kms
Pennzoil Platinum 5w-30 D1G3 w/ FL-910S Filter - 152,282kms
Tire Mileage Log:
OEM BFG KO2's - 66,985kms
Falken Wildpeak AT3W 285/70R17 - 64,630kms
In: 152,282 Out: ---​
Total: 14,269kms​
In: 145,855 Out: 152,282​
Total: 6,427kms​
Mod Log:
MRT Hood Struts - 200Kms
MRT Trail Rated Turn Down Axleback - 200Kms
Mishimoto Catch Can - 200Kms
JCR Tailgate Table - 200Kms
IAG v1 OEM Rock Rail Steps - 200Kms
GCPA Hardtop T Bolts - 450Kms
Kicker 46CSC674 - 6 ¾" CS - 550kms
Kicker 47KSC404 - 4" KS - 550kms
Diode Dynamics SS5 Sport Combo Amber - 1,230kms
RekGen Trophy Standard Front Flaps - 1,230kms
BYB Picatinny Rail - 1,230kms
Assorted Molle Gear - 1,230kms
Diode Dynamics SS3 Max SAE Fog Amber - 3,000kms
OEM Aeroskin I - 3,000kms
Got Naked for the First Time - 3,500kms
RC Hidden Winch & Pro9500S - 3,800kms
Bartact Grab Handles/Molle Bags/Door Bags - 20,342kms
Hertz CX100 4" - 23,000kms
Diode Dynamics Hitchpod - 30,363kms
JCR Spare Tire Rack - 32,000kms
Suma Mirrors - 32,000kms
DIY Mishimoto Catch Can Drain - 34,500kms
RotoPax, Mount, Custom Spacer - 35,600kms
Oracle BRONCO - Black w/Amber - 36,500kms
Seat Back Protectors - 36,500kms
IAG v2 OEM Rock Rail Steps - 36,500kms
Baja Designs LP9 Amber Driving Combo w/ Capable Light Mount v1 - 36,500kms
Rough Country D-Rings - 40,400kms
MoarDoor 2.7 Auto Tow Spring Swap - 43,580kms
IAG Foot Pegs - 47,000kms
Trailgear Oasis Cover - 48,000kms
DIY Paint Correction - 50,960kms
Underground GFX - 50,960kms
Rough Country Hidden Winch & Pro9500S - 51,250kms
Powerbass XL-42SS - 56,985kms
IAG LED Interior Light Kit - 67,704kms
AuxBeam 8 Gang Switch RGB - 67,704kms
Baja Designs S8 40” - 67,704kms
Turbosmart VR19 DP BOV - 68,369kms
Diode Dynamics SSC1 Pro Flood Flushmount - 69,312kms
Diode Dynamics SSC2 Pro Combo Flushmount - 69,312kms
3W Liners Floor Mats - 69,350kms
Steeda Clutch Spring - 69,390kms
5% Sunstrip - 71,530kms
Ford Performance M220 Diff Cover - 84,255kms
Rockslide Engineering Roto Pax EZ Mount - 85,019kms
Plug N Play Harness - 85,200kms
Kicker Key 200.4 - 85,200kms
AudioControl LC2i Pro - 85,200kms
Hifonics Brutus 1200.1D - 85,200kms
Focal E30KX K2 - 85,200kms
Focal 1.1000 FPX - 86,121kms
Optima Yellowtop - 129,261kms
2x Pioneer TS Z10LS2, Custom Boxes and Internal Rack - 132,570kms
BDUSA Vent Tabs - 140,051kms
ModCrate Latch Plates and Bushings - 140,683kms
Suma Mirrors (warranty) - 149,985kms
Method 703 17x8.5 +35 Bronze
Future Mod List (in no particular order):
Items Ready to Install:
El Cheapo Rocklamps (one on each corner plus two under hood, cause the mall can always use more lighting)
Auxbeam Light Controller
Oracle Tail Lights
Front Brake Pads
Dashcam
On Order:
N/A
Bronco Hitch Accessories:
Camper - 2024: Axle upgraded to 3500lbs. 2025: Lighting replaced and rewired. Charging system revamped. Roof rack built with awning, cargo box, spare tire and solar shower. 2026: 24v converter, Starlink, redo interior switch panel
Wilco Hitchgate - converted from full-size spare tire carrier to a snowboard/ski carrier.
Kuat Sherpa 2.0 - Picked her up second hand, like new.
Recent Photo:
Ford Bronco The Boreal Badlands May 20, 2024_6425-LR
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
The Green looks stunning under the lot lights. Fingers crossed that PDI goes smoothly and she’s on the road for next weekend
Ford Bronco The Boreal Badlands D06558EC-B208-4FDD-90EE-BBC3F6957572
Ford Bronco The Boreal Badlands 2A859E8F-4ABA-4AB0-B01C-F1B8F27E2FAE
Ford Bronco The Boreal Badlands CBC28230-B49A-4998-AFD8-ED8B985292DA
Ford Bronco The Boreal Badlands 6B87FA61-0539-4A56-92D9-BB6300DAD5AD
Ford Bronco The Boreal Badlands 7819CF6A-2FA8-4EFE-88A2-A0216259827F
NORCALGXP
Sacramento, California
2017 Raptor
Two door score.
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Well, this was the longest four days I've experienced in a long time... Steeltown Ford in Selkirk, MB (can't speak highly enough about them) got a rash of deliveries over the weekend amongst their normally busy schedule, there were 12 vehicles waiting for PDI and three of them were Broncos.
Monday I emptied out the Base Bronco, luckily I ran a clean ship and there was very little to move out.
My man Mitch (shoutout to Shawn too) got in Tuesday and called me up to get an appraisal of the Base - they wanted to try its hand at Auction; it won for MSRP with 20,000kms on the ODO - Broke even after seven months, nice. Got to take the Badlands for a test drive while they looked over the Base - Eruption Green wasn't the only thing Erupting with how hot this ride is. And wow, is the large screen something.
Ford Bronco The Boreal Badlands July 07, 2022_4339-LR
Ford Bronco The Boreal Badlands July 07, 2022_4554-LR
Wednesday we did some financing and the shop PDI'd the rig!
Come to Today, Its finally in my hands! First dirt wasn't far behind... first mods are tomorrow, let the games begin!!! (Peep that Soft 4DR CO Big Bend)
Ford Bronco The Boreal Badlands July 07, 2022_4383-LR
Ford Bronco The Boreal Badlands July 07, 2022_4342-LR
Ford Bronco The Boreal Badlands July 07, 2022_4359-LR
Ford Bronco The Boreal Badlands July 07, 2022_4433-LR
Ford Bronco The Boreal Badlands July 07, 2022_4401-LR
Ford Bronco The Boreal Badlands July 07, 2022_4410-LR
Ford Bronco The Boreal Badlands July 07, 2022_-LR-3
Ford Bronco The Boreal Badlands July 07, 2022_4457-LR
Ford Bronco The Boreal Badlands July 07, 2022_4524-LR
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
First Fix was also made. The drivers seat failed to slide forwards when you pulled the shoulder lever as if to climb in. I recalled reading a thread a while back where the Molle seat back panel fell straight off and Flip had shared some valuable info on how to install/remove the panel... So off the seat back went, turns out the cable that actuates the slider had popped out of its holder. Thanks @flip for the inadvertent help!
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Less than 24 hours, and only 200kms on the odo, the badlands and I headed off to my good wrenchin buddy Jared's place. We started off with the @IAG Performance v1 Steps. Straight forward, no BS, and work as intended... no more need to worry about seat wear while sliding in and out (short leg gang)
Ford Bronco The Boreal Badlands IMG_7456
Still waiting for the car to cool, We tackled the @JcrOffroad Tailgate Table. I broke 3 out of 4 tabs on the "Accessory Ready" plastic vent... hope they don't rattle down the road. Other than that, it went pretty damn smoothly!
Ford Bronco The Boreal Badlands IMG_7452
Ford Bronco The Boreal Badlands IMG_7455
Ford Bronco The Boreal Badlands IMG_7458
Ford Bronco The Boreal Badlands IMG_7459
The Table install took a good hour considering I did not do any prep reading and I hadn't even cracked open the shipping box. Too peeps make this job much easier than if you were to tackle it solo.
Now that rig was cooled off enough I threw the @MRTperformance Trail Rated Exhaust back on (reclaimed from the Base)... Its sooo nice to hear the revs to shift with, the few days I had with a stock axle back before the Base trade in were not as smooth as months past - its too damn quiet. Glad to have that rumble again!
Ford Bronco The Boreal Badlands IMG_7463
The muffler swap took all of 4 minutes with Jareds exhaust hangar tool... much quicker than my previous 45 minute struggle of laying on my back with a flathead and wd40... fresh hangars are a bitch without the right tools. Continuing on the @MRTperformance trend, Hood gas struts! Again, two people make this job much easier considering we have to unbolt the hood from the hinges.
Ford Bronco The Boreal Badlands IMG_7462
Ford Bronco The Boreal Badlands IMG_7461
Ford Bronco The Boreal Badlands IMG_7460
Ford Bronco The Boreal Badlands IMG_7471
Finally, the big one... the @Mishimoto Catch Can for the 2.3. For the life of me, I don't know why we don't just hook up to the hose that we remove on the top of the Intake... the instructions are incredibly vague and if it wasn't for @Tanman and his Tips and Tricks, the install would've been mind boggling. There should be a redesign of the Catch Can kit to utilize the factory piping, not everyone wants to pull the fender liner and fight with a completely blind fitting that has a stupid ass proprietary clip. Jared's lift came in real handy for giving us a stable platform to work with. In the end we were victorious and time will tell how effective the Catch Can really is.
Ford Bronco The Boreal Badlands IMG_7466
Ford Bronco The Boreal Badlands IMG_7467
Ford Bronco The Boreal Badlands IMG_7468
Yup, the fitting is in there... behind the rear most UCA mounting point, and up under the intake manifold... Stupid.
Ford Bronco The Boreal Badlands IMG_7470
Ford Bronco The Boreal Badlands IMG_7472
Not bad for Day 1. My Kickers all arrived and the SS5's are here too. Hopefully I can find some time next week to get the speakers swapped over!
Till next time, Keep the rubber side down!
mcinfantry
Lee
Louisiana
Badlands 2 door
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Why? Don’t you already have six switches?
same?
The way that I’ve broken up the zone control for the lights have left requiring more switches than available. I originally mapped out something like this:
Aux 1: High Bumper mounted LP9’s - Low Beam
Aux 2: Cowl Mounted Spot Pods
Aux 3: Cowl mounted Ditch pods
Aux 4: Roof Mounted S8
Aux 5: Reverse Pods
Aux 6: Winch
AUXBEAM 1: High Bumper mounted LP9’s - High Beam
AUXBEAM 2: DRL’s - S8, LP9’s, SS3’s? SSC2’s,
AUXBEAM 3: Rock Lamp Interior
AUXBEAM 4: Rock Lamp Engine
AUXBEAM 5: Rock Lamp Exterior
AUXBEAM 6: Oracle Grill Letters
AUXBEAM 7: Spare
AUXBEAM 8: Spare
and the Manual Trans peeps don’t get any of the remote start features through the Ford Key or Ford Pass App… it’s too much of a liability so here we are in 2022 still wiring in brains and antennas as if it’s 2005 😂
NVCowboy
William
Henderson, NV
Me: I don’t need the big screen. I have one with no screen at all, and two with 8” screens, and those are plenty. I mean how much difference is there really . . .?
Now me: Damnit!!
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Now me: Damnit!!
Yeaaaa, that was my thoughts with the Base... Do I really need anything more?.. Yes, its not just the size but the full High Pack capabilities that make this suite very much worth the upgrade!
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
GCPA Bolts thrown in, and still haven't had a chance to take the roof of either rig so far. Between the bitterly cold winter, the torrential spring and continuing on as a wet summer, we have hardly had more than two days of good weather at a time
Ford Bronco The Boreal Badlands IMG_7516
Ford Bronco The Boreal Badlands IMG_7515
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Yes, another Kicker install. The Kicker 46CSC674 (6 ¾" CS) and Kicker 47KSC404 (4" KS - x2 - Dash and Roll Bar), are all installed with no fasteners/clips broken and extremely minimal plastic marring around the Dash Grills... why the hell do these plastic grills need six fasteners, they aren't ever going to go anywhere... I basically needed a crowbar to break them free. Anyways, not to many photos taken along the way as I was in a good groove.
I added some sound deadening to the kick panel speaker and to the rear pod enclosures. Every speaker and the metra adapters got a rear foam gasket to help with potential rattles... not like any of these enclosures are actually sealed or anything. I didn't bother with the 4" speaker harness plugs, it was easy enough to lop off the end and put some blade connectors on. As many have mentioned, 300hz caps were put inline for the dash speakers.
The CS 6 ¾ were picked for the kick panels for their loudness. The KS 4" were picked for their silk tweeters, reducing the metallic harshness of the treble bouncing off the glass. Im tempted to try the for scan mod for the rear pods cause damn, they are pitiful as factory programmed.
Ford Bronco The Boreal Badlands IMG_7524
Ford Bronco The Boreal Badlands IMG_7520
Ford Bronco The Boreal Badlands IMG_7521
Upon first drive, the clarity is night and day compared to stock. Im extremely happy with how vibrant and clean the audio now sounds... however, Its not enough. The @plugnplaykits Key 200.4 kit will be on the shortlist next time they are in stock, that should really bring the sound stage to life... The factory woofer enclosure has been on order for a a few months still with no ETA.
As is, im pumped with the much needed upgrade!
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
It may only be two doors, but you can fit four quad wheels inside! I am workin on refreshing a 1986 Honda Fourtrax 350, the front disc brake retrofit needed some larger rims to clear the calipers… 36 year old rubber probably isnt the best anyways
Ford Bronco The Boreal Badlands FB049DB5-0030-4CA4-A398-559B541A5276
I’ve hopped onto the @Mabett Train with the center console tray - this thing is the perfect height for the everyday stuff
Ford Bronco The Boreal Badlands B623CCE5-A3A1-4909-A4E0-8578E8C6F18C
as well as the TPE cover… Bella loves to stand on the center armrest, best to protect it from her claws in the long run
Ford Bronco The Boreal Badlands AFA6AAF9-29A7-4B4B-A76B-6B163668C00E
and finally, a front seat dog cover! No more camp blanket on the seat and considering she’s my passenger more than people, best get a durable cover - even if it’s an Amazon special
Ford Bronco The Boreal Badlands 9B2B99E2-50B3-4709-9A88-A35134DF0A18
Ford Bronco The Boreal Badlands E5DBB696-5878-49F4-9262-CBEA5789FCE5
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Another Mod Day!
Rekgen Front Trophy Flaps - these needed the crash bar window cut out. With some help from pops, I made quick work using an oscillating cut. No instructions made the install somewhat of a game/puzzle. Nevertheless, I was victorious!
Ford Bronco The Boreal Badlands 7A60AB4D-977E-4441-89D9-AC0BBB8312EA
Ford Bronco The Boreal Badlands 3BE40607-C273-4919-887C-BF4D92D350F5
Ford Bronco The Boreal Badlands C42E71AE-EE5C-4BCB-B10C-F92597015658
Ford Bronco The Boreal Badlands 5ACD7AD8-6821-4F84-947C-47294C965616
Buck Your Bronco Picatinny Rail - straight forward, exactly what I was looking for. I opted for the GoPro mount to use for Timelapse’s or as a trail cam for days in the bush. AND They were cool enough to send it all in a Molle Pouch! Shout out to @Buck Your Bronco. For the record, the pouch fits the seat back perfect, but it does not fit with the wider slats on the JCR tailgate table - not a complaint, just worth mentioning
Ford Bronco The Boreal Badlands 5517B2F7-8A1F-4BDA-9EE5-9A4981B832C3
Ford Bronco The Boreal Badlands 55786DF3-FF48-4F7E-B7EF-4C1C61A68992
Got a home for a first aid tear off Molle pouch on the tailgate… the supplies are still enroute
Ford Bronco The Boreal Badlands 6C97E4CC-CEC1-490F-A9BA-C3ABFAC32D2B
Also in the cards was the @Diode Dynamics SS5 Sport’s. I think I need a stubby antenna or an antenna delete, at worst, I machine up a new light mount. We will see what I do, but for now, they are on! I made my own harness using their pigtails and tied the lights into Aux 2.
Ford Bronco The Boreal Badlands 19DA1ED6-FE72-4156-A1A0-C2F98A124C60
Ford Bronco The Boreal Badlands A88817FD-84DA-4B66-A67A-90C32E06CAE3
Ford Bronco The Boreal Badlands 6582421D-D7C2-45A3-85F4-A8E13CB49272
Finally, my damn driver seat cabling popped out again. Pulled the seat back off, and tensioned the cable and housing with zip ties. I don’t have time in the schedule to visit the dealer for this so it’ll have to work for now… if it breaks again, I’ll address it with warranty
Ford Bronco The Boreal Badlands 07FCC910-A73D-4111-9FAC-87C3D9D5B627
All in all, a decent wrench session. Now to dial everything in on a cabin trip. LP9’s, SS3 Fogs and the RC winch kit are hopefully up soon
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Another Mod Day!
Rekgen Front Trophy Flaps - these needed the crash bar window cut out. With some help from pops, I made quick work using an oscillating cuter. No instructions made the install somewhat of a game/puzzle. Nevertheless, I was victorious!
Awesome!
We hope you're loving our SS5 LED pods as ditch lights on your Bronco!
