BAUS67
BAUS67
redneck
Central PA
Lost some more bits tonight>>>>>>>>>>>>>>
I believe this is the shot you were looking for @Aztec1382
Ford Bronco The "Baus" Bronc IMG_0536
One with a tape measure, if it helps. The end of the tape is on the pipe. The front of that pad is 2 3/8 off the pipe.
Some shots of the "bits" missing. :LOL: And the clearance I have now.
Ford Bronco The "Baus" Bronc IMG_0539
Ford Bronco The "Baus" Bronc IMG_0540
I hade to see if it was any better now with the bumper on.
In this pic I got the winch plate up to the bottom of the bumpers "pocket".
Still tucked in nice.
You really have to lean to start to see the winch.
Messed around some more and managed to get the plate up to damn near the bottom of the frame and still not hit underside of the top of the bumper. 😁 I was losing light and had to go pick up my son from soccer practice. Hence the flash on the second. You can also see it is not as high up as it is on the opposite side. The surface I am working off of is not level. When I get it in the garage to finalize the template it will be better.
Ford Bronco The "Baus" Bronc IMG_0545
I'll be making some frame bracket templates starting tomorrow so stay tuned. If ya'll need anymore shots let me know. 😁
618TRVLWILD
Ashley
Southern Illinois
Big Bend Sasquatch 2D
Thanks Ash !!!!!!!! 😎 🤘 Have not seen you much lately. How have you and Mae Pearl doing???? Last I heard you had a bit of a front axle issue???? :unsure:😁
Oh that front diff took a poop on me! We are doing well tho. Adding those miles up!
Ford Bronco The "Baus" Bronc 186B3378-BD05-4AEE-BC05-5E78C1AEF263
Ford Bronco The "Baus" Bronc FB2425EC-F687-462B-B04D-EDD20230B242
BAUS67
BAUS67
redneck
Central PA
Just updated post #3 !!!!!!! 😁
Got my front bumper installed and as usual ran into some issues, but nothing the cut off wheel couldn't handle. ;)
Afterwards I took it for a spin and found something a bit more appropriate than a curb to get some "action" shots. :LOL:
Ford Bronco The "Baus" Bronc IMG_0610
Kinda "dorky" looking without a winch in there, but I'm working on that, hang in there.
Honyock
Nate
TUCSON
1976 F350, 2004 S211 E500 (22 Base + manual + SAS)
curious if you still like this bumper after having it for a bit, been looking to add something similar, looks closest to the look I have in mind. I had bought a winch mount that looks like would work with this since the shackle mounts look basically the same as a modular OE style. I did modify a stock OE plastic one to fit with the winch bracket and bull bar, but this looks like it should give slightly more protection that the light plastic ones
BAUS67
BAUS67
redneck
Central PA
Yes, like it very much. It is very similar to the OEM mod bumper. Those winch mounts that go to the shackle mounts will work good as this bumper has some beefy reinforcements. I found Black Horse Off Road is another company that offers a similar bumper.
Hard to believe this has been 3 months ago. My how time flies. I have to get back on the Bronco projects before the snow flies. ;)
j_marinelli
Spring Branch, TX.
Honyock
Nate
TUCSON
Very interested in your winch location idea as I decided to get this Baja style bumper instead from Reaper Offroad.
There looks to be the perfect location for the fairlead to sit right above the bottom bar if the intercooler moved north like yours.
Ford Bronco The "Baus" Bronc 1693522776921
BAUS67
BAUS67
redneck
Central PA
Yes, that does appear to be more than adequate space. My winch/fairlead/winch plate needs almost 8", top to bottom. Good candidate.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
If I had to do mine over I would invert the winch so it bolts to the top of the bumper. This way the fairlead is higher and probably easier to access the free spool from below.
Ford Bronco The "Baus" Bronc PXL_20230709_000013023
BAUS67
BAUS67
redneck
Central PA
That's a good idea, never thought of that.
Aztec1382
Sam
F350
That’s exactly what i was thinking as well
Aonarch
Jack Hoff
MT
Looks great!
