The 6G really isn't a rockcrawler.
Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
you can throw after market UCAs and a spring perch lift on the Bronco and get all the belly clearance you need to match the Jeep with it's 2" lift (solving the OPs original issue
BS. The Sasquatch with us had that 2" lift, spacers front and rear, and struggled every bit as much. Have you even looked under a 6G and saw how low it hangs? Double that and you'll finally start being somewhat competitive.
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
Yes you can fit 35s on a stock JL Rubi you really can't wheel with them (you're going to rub doing anything).
So 35’s with no modifications is not an accurate statement
33’s it is
Sure, if you're judging the need for modification on 1% of use case. I have two friends in JLURs stock everything except 35" KO2s on stock rims. They wheel the hell out of them, all over Colorado and Utah. But go ahead and pull out that tiny fractional situation to try to prove your point. (y)(y)
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
I'm just going to go ahead and say it (nicely):
If you expected a Bronco to do 100% of what a Jeep does then you aren't very smart.
If you expected a Bronco to be buildable to do the hardest 15% of trails then you aren't very smart.
Ford Bronco The 6G really isn't a rockcrawler. missed
GPPBronco
Detroit
linktr.ee
ā€˜23 Toyota 4Runner TRD Off Road
Everybody else on that trail with similar size tires had no issues because
they had far more belly height.
This is the sneaky subtext to ā€œcomes from the factory with 35’sā€ which everyone gushed over when the 6G was released. That’s the tire size you need to install in order to go head to head with the wrangler rubicon on 33’s.
I also wonder if the ā€œdesert runnerā€ bonafides was partially a marketing decision to explain away the clearance issues for rock crawling.
As a Great Lakes region flatlander, 33’s on my base will do everything I need it to (farm lanes and forest roads). But it’s gotta be frustrating to the rock crawlers among us.
mcinfantry
Lee
Louisiana
Badlands 2 door
Why make absolute statements?
You made it I didnt
I agree the bronco won’t run with the jeep
I also think a stock JLUR is shitty at long distance driving to the trials…. And I couldn’t imagine a lifted one. I saw a guy at ajeep event ask a JLUR owner in 38ā€s if it rode as well as stock. It can’t. By definition it’s all a trade off. Everything is.
but that’s my personal experience of 6800 miles over three weeks, 12 states from Louisiana to Wyoming to Moab and elsewhere
I just want it (my bronco) to see the US. Travel and enjoy the rest of my life.
But I agree with a few comments. If I want to rock crawl exclusively I’ll build/buy a buggy or sxs and a trailer to haul it
all I’ve ever built and owned was driveable off road vehicles
some with 39ā€ tires and some on 31’s.
im older now and honestly still enjoy all the ingenuity and work I see people try and do
ā€˜21OBX
Ken
90Bronco19
2022 bronco outer banks
Did Ford really need to make this boat anchor X-member in their premier offroader (see 5:03)
Haha hung up his are barely touched. Mine are flattened from Drummond island. It is a shame Ford couldn’t keep these even with the rest of the frame. Skid plates barely touched. I’m going to have to get after a high clearance version of these cross members. My warranty needs to expire before I start cutting things up tho.
Jdyount
Kansas
2021 Badlands
The B6G doesn't hang any lower than any other off road vehicle, the bottom is always the frame rail (unless something is hanging below the frame rails like the transfer case on the B5G). What differs is the verticle distance between the bottom of the frame rail and the axle center line (a suspension lift modifies that) and half of tire height. I don't know what the exact difference is but I'm sure we can find it.
Apples
Nick
Tricky Dick
Dick
PNW
I'm really curious to see what the RCLT from marlin crawler will do. IT my help you @Tricky Dick but still no ETA
What is the RCLT? If it's a smaller fuel tank than yes.
Yeah there's a few things hanging below the frame.
Ford Bronco The 6G really isn't a rockcrawler. PXL_20221004_000702661
Ford Bronco The 6G really isn't a rockcrawler. PXL_20221004_000742245
mcinfantry
Lee
Louisiana
Badlands 2 door
Because it doesn't require any modifications to run 35s.
Here's 46 pages of people doing exactly that. https://www.jlwranglerforums.com/forum/threads/jlu-rubicon-on-35s-no-lift.7290/
Fascinating link
First and last pages both show aftermarket rims. So I lost interest.
I ll take your word that the middle pages are FULL of stock JLURS with no other modifications running 35’s
stock means stock
and no other modifications means none.
stop stating facts and then backpedaling on them
just say ā€˜it doesn’t take a whole lot to run 35’s on a jlu or even the JLUR of you don’t mind some rubbing, some trimming or some aftermarket wheels
I know it’s hard. But try it
Status
