Territory MT vs territory RT replacement tires
straycatboat
rick
bronco 2023
My 2023 Sasquatch came with Goodyear territory Mt tires and now at 25K miles they are worn out and I need a replacement tire,
Has anyone experienced the RT territory as a replacement as far a noise/wear comparison. Dealer is quoting 4 new RT's @ $1122.00
straycatboat
rick
bronco 2023
5280Bronco
Denver
In before 5 tire rotation strikes
Yep... that was my first thought. Lol.
Sorry OP, I don't have feedback on the tires themselves. We're just saying someone is going to ask why you are replacing just 4 and not all 5, due to the 5 tire rotation process.
straycatboat
rick
bronco 2023
I quit the 5 tire rotation due to weight of the spare replacing on the carrier.
I rotated the tires every 5K when I changed the oil/filter
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
When I switched off of the Territory MTs I rotated the spare in 4 times, and now its going to stay there so that when I do a replacement I'm only replacing four.
phillyfx4
Rich
Phila., PA
2008 F 150 4X4
just broke 7K with my 2025 OB Sasq.....surprised how well my GY RT's did in the snow and ice, with one caveat, they are slippery on wet and ice. But most tires have that "challenge" . Wearing well and I do 5k rotations (with spare). With some criticism I've seen about them I'm satisfied so far
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
MTs look and perform far better than RTs.
Replace MT's with MTs.
Replace RTs with MTs.
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
JawnyBronco
DelMarPa
2023 Bronco 4dr
I would like to clarify, when Goodyear says MT, they mean "Maximum Traction" - rather than "Mud Terrain" like the rest of the tire industry. I can only extrapolate that to mean that Goodyear means "Really Good Traction" when they came out with the RT line.
So the advice to replace MT with MT, or RT with MT, needs a good bit of clarification in the context of Goodyear tires.
(I agree with the Mickey Thompson interpretation, by the way)
BearPatrol
23 Bronco
I replaced mine at 66k. They held up better than I expected. Gripped well when wheeling, & had solid traction in some crazy i70 ski season blizzards. Only 1 flat ever & used that as a sign I had put replacing them off long enough.
brkdncr
Southern California
Toyota 86
If you offroad at all then find something else. Punctured my 3rd tire two weeks ago. They are the lightest a/t on the market and it came out of the sidewalls.
