Takeoff Sasquatch from 2.7 on a 2.3?
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
I have a really good deal from a shop that has Sasquatch suspension from a 2.7 4 door. I will be receiving by bronco in the next week or so. I have a 4 door black diamond 2.3. I want to know if it would be ok to install the Sasquatch suspension from the 2.7 on my 2.3?
RagnarKon
Ford Bronco, Escape, Focus
Yes, should be fine.
The only issue is the spring rates may not match up. 2.7L is obviously a heavier engine than the 2.3L, and therefore those takeoffs likely come with stiffer springs from the factory than what would normally come on a 2.3L Black Diamond.
Which means your ride quality may not be the most ideal, but it's only an issue if you care about that sorta thing.
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
That was what I was thinking but I was think also the black diamond weighs more than the OBX by a little bit much.
RagnarKon
It'll depend if that OBX had the HD modular bumper. If it did, then I suspect the fronts will be a little on the stiff side. If it had the standard plastic bumper the weights probably will line up nicely given you have a steel bumper and bash plates.
Aonarch
Jack Hoff
MT
Check the suspension cookbook thread on part numbers and trims.
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
this is a photo of one of the shocks. I didn’t see it on the list
Ford Bronco Takeoff Sasquatch from 2.7 on a 2.3? IMG_8514
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
It had the plastic bumper.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
it's the springs that you want to compare for part numbers
(or you could find out how the donor vehicle was optioned out.
if it started as a badlands w/ mod bumpers and auto transmission, it'll definitely be stiffer)
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
It was an OBX 2.7 4 door no tow and plastic bumper.
pwork
Patrick
Southern Illinois
GTI/Sportwagen/Frontier
It'll be stiff and the front will be level or slightly above the rear especially with anything on/in the back. I'd try to find some badland 2.3 take offs or at least the springs. I have a 2.3 BD, added squash 2.7s and it rode ok, but when I put my bike rack on, it was squatted. I put the 2.3 BL fronts on and now its level or slight fwd rake, and rides much better. Make sure you get an alignment too.
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
The main reason is I am getting the takeoffs and running boards for $250. I was going to resell the running board because I already have them. So it would almost be free.
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
The shop sent a picture and it came off a wildtrak? Do they come with those shocks? I thought they had Fox.
pwork
Patrick
Southern Illinois
some of the wildtracks had the fox/3.0. that's a smoking deal, i'd do it either way and sort out the front springs. I haven't found a PN for a 2.3 w/ squash yet tho...
