Tailgate table for Bronco Raptor?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I’m looking for a tailgate table for my Braptor…. I’m undecided between the goose gear and Outback adventures….. anyone have any of these installed and what do you like and dislike?
Go with the Goose-Gear. I had looked at both myself and settled on the Goose-Gear. Loved it so much, we became dealers for Goose-Gear (paid full MSRP for my own table on our bronco)
It's a great add-on and we sell it here: https://www.4x4truckleds.com/goose-gear-tailgate-table-for-2021-ford-bronco/
Ford Bronco Tailgate table for Bronco Raptor? Goose7
Benzo
Ben
Bay Area CA
too many to list
I don't think you can go wrong with either choice. It comes down to the cost, cable or no cable, full cutting board or not, and what you think you like best.
I opted for the tailgater with less cost, larger cutting board, and magnetic rail. I have 0 complaints. It has not made any noise and it has worked very well. I have not had any issue with the cables and the full side cutting board is very nice. I opted for the grey hammer finish and I would happily buy it again if I needed to.
Tapatio55
CT
I installed the oem table. Took a few hours. It’s fine for my purposes but only holds 25lbs ish. I am not sure how those heavy duty tables are screwed into the tailgate but the oem one you install metal anchors into the gate sheet metal and the anchors hold the screws for the table. I wouldn’t want to put a lot of weight on a table as you are basically just pulling against the metal skin of your tailgate. At least I’d make sure there are more than 4 anchor points. On a side note I installed the under trunk safe and it’s super easy and fits and works great without giving up any storage space.
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
i returned my OEM one, sorry not drilling into the tailgate of a braptor for a table that only holds 25lbs and has cables. keeping an eye out for a no drill solution or a definitive winner, so that I only have to drill once.
AK SNO RIDER
Ty
Alaska
The Trailgater is no drill and rated at 50 lbs. It uses plastic inserts that go into the existing slots in the tailgate. They seem kinda chintzy at first but once it's all installed it feels perfectly solid....and no drill.
It does have cables though... not that I've ever even really noticed them 🤷‍♂️
monsterfd
thank you for clarifying, this is a compromise im willing to make!
NJBronco
New England
2019 Colorado Bison
Can you elaborate on the under trunk safe? Is that a Ford aftermarket part? Any links or pics? Thx
BlackDog
MI
F Series
I picked up the rough country table. Simple and clean. Shelf has holes for bags/straps etc. I believe rated for 75lbs-check that first.
Also under 100$ bucks shipped free and fast. I don’t have the bronco to mount it but the table is nice.
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
FellowM3
Northern NJ
Post some pics!
Also, from the pics, it looks like Goose Gear cutting board is the same size no? Is trailgater's really bigger?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
AK SNO RIDER
Ty
Alaska
Post some pics!
The Goose Gear board isn't a full rectangle, it's cut to fit the tailgate latch bump. Look close, you'll see it.
The Trailgater board is a full rectangle.
As for which one has the most usable square inches...no clue.
Idk if Goose Gears can do this...I haven't looked that closely at the design (anyone know?), but Trail Gaters cutting board can be used on either side of the table. May not matter to anyone but thought I would point it out.
Ford Bronco Tailgate table for Bronco Raptor? 20220712_070457
Ford Bronco Tailgate table for Bronco Raptor? 20220712_070445
Primed_in
New Mexico
Ford Edge
I'm going for the OEM one which I heard is flimsy but, free with my points so...
I use the OEM one all the time with no issues. Ammo, camp grill, etc, works just fine.
Tapatio55
CT
