Tailgate limiter
CalvinT
Calvin
Phoenix, AZ
I bought the Warhorse limiter. It uses the factory strut. It just relocates the mounting point on the tailgate.
I've been happy with the M2M brace. It also uses factory strut.
But I am on my third strut...
I never could find replacement ends for the strut - mine the one on the Bronco side keeps wearing out then it starts popping off. My first one went before I got the brace, so I don't think that has anything to do with it.
Lifeliberty
Moonbeam👀
Columbus, OH
The plastic piece on the end of my Warhorse limiter seems to have chipped a little chunk off the inside and will no longer stay attatched to the ball mount. Warhorse does not seem to be around anymore. Is this a piece I can buy elsewhere and swap?
No one has been able to find replacement ends yet. You have to buy a new strut https://www.varsityfordparts.com/oem-parts/ford-assist-support-m2dz78406a10a?origin=pla
I was able to fix mine by removing the metal spring inside the end piece, using pliers to pinch it for more tension, and putting it back together. Hasn't popped off since. Been at least a year
midcont
N.J.
Gladiator
thanks. Tried squeezing the clip more than once.
can somebody confirm if the female side mounted to strut is perfectly spherical? Mine definitely appers not to be anymore.
Mine wore out and looked like that. Squeezing helped at first but didn’t last
It’s fun when it lets loose while you are parked on a hill
OldMetal
Tom
Dallas, TX
2008 GT500, 2008 F150, 1977 Cadillac Eldorado,
This looks great. People have mentioned that some tailgate limiters can bend the sheet metal and do damage. Can anyone mention if this design looks like it might do the same?
Depends on how it connects on the open end of the tailgate I suppose. There's no threaded insert or nut/bolt on that end to connect to, and I could see if you didn't have some secure method of installing that end, that you could warp where the brace bolts into the threaded insert on the hinge side of the tailgate.
M2M uses a long bolt and a steel plate that pulls against a piece of interior brace of the tailgate up by the latch to hold that end solid, and I've had my 38" tires on there for a long time, including many failed struts where it's slammed open hard (stupid plastic ends on the struts either wear out or break)- and the M2M brace and the way it connects to the tailgate has been solid and it's saved my taillights many times. I can't speak to any others though.
GI_Jo_Nathan
Jonathan
If only it had a strut to hold the gate open.
Not sure I understand you. 🤔
The factory strut holds it open in most situations.
Lifeliberty
Moonbeam👀
Columbus, OH
GI_Jo_Nathan
Jonathan
