"System Off to Save Battery" While Driving
BigBlue7
New Jersey
‘23 Black Diamond Sasquatch
2023 2.7 with 2500 miles. Drive it daily. This morning this popped up 10 minutes into my morning drive
My voltage was constantly bouncing between 15.6 and 14.9v
When the bar filled up the sync unit shut off and I continued driving just fine. I held down the power and skip ahead buttons and the system popped right back on without even going through the standard startup animation
Any idea what it could be?
Ford Bronco "System Off to Save Battery" While Driving IMG_0401
Ford Bronco "System Off to Save Battery" While Driving IMG_0402
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
15.7 sounds pretty high. I thought 14.4 was about the max normal range.
I almost wonder if it was an overvoltage protection but to the APIM, it was just seen as loadshedding.
Silver-Bolt
Eureka, MT
Is your commute typically short? Short drives will deplete the battery over time. Get it out and run some miles without starting and stopping it.
BigBlue7
BigBlue7
New Jersey
Yesterday I drove 45 miles in the morning and another 45 miles in the evening. Some days I work from home. I Have 2500 miles in 2.5 months. This isn't from lack of driving
Bought 2.5 months ago. Blend date of early August
[DELETED MEMBER 27901]
I will see 15.1V on that gauge sometimes so I don't think that's your issue. I'd start with fully charging your battery and checking for the latest version of Sync.
As much as I love this vehicle there's no lying the infotainment is absolutely terrible and the charging system is undersized...
BigBlue7
BigBlue7
New Jersey
Also, I have not received any sort of alerts or notifications in my Ford Pass app.
Ducati1098
15.7 is pretty high, but it isn't much higher than what it should typically vary between. It may be high enough to start making certain modules act up though. Normally high voltage would illuminate the charging system light and more than likely set a DTC depending on how long the condition lasts.
Normal range according to the workshop manual should be between 12.2-15.2 depending on whether the battery is in a refresh phase or not. Personally I would just keep an eye on it, and see if it happens again.
Aonarch
Jack Hoff
MT
Ironically I got the same message in my app yesterday, but I know my battery level of charge is fine. I ignored it.
BigBlue7
BigBlue7
New Jersey
Thanks. It was also 35 degrees here this morning if that changes anything.
About two weeks ago as I was pulling into a parking lot I got an alert on my dash that said "Service Charging System Soon". I shut the car and went inside. Came back out to my car 5 minutes later and turn it on an the message was gone. Again, never receive any sort of notification or alerts in my FordPass app.
Think the two messages (about two weeks apart) are related?
Ducati1098
Thanks. About two weeks ago as I was pulling into a parking lot I got an alert on my dash that said "Service Charging System Soon". I shut the car and went inside. Came back out to my car 5 minutes later and turn it on an the message was gone. Again, never receive any sort of notification or alerts in my FordPass app.
More than likely, yes. In that case I would bring it into your dealership. The codes stored from that fault should still be present.
vrtical
Doug AI
GSMNP, TN
Fords
I get it all the time but not while driving, I mostly ignore it only because it seems to be sensitive to any kind of drain. My pods have backlight and tied to the accessory lightning so the timeout on that circuit is like 5 min.
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Happened to me. Replaced my alternator under warranty. Took only a few days since they had to order parts. No questions asked. Does this look similar?
BigBlue7
BigBlue7
New Jersey
Yup! Extremely similar. Mine wasn't bouncing back and forth quite as fast, but definitely was similar.
I just went to Autozone and they tested the battery and alternator to the best of their ability and everything checked out fine. Bringing it to the dealership at 11am tomorrow.
How quick were the able to diagnose your issue? I'm worried that my dealership will say everything is fine because they can't recreate the issue
23_Badlands
US
'25 Tacoma Limited, '23 Bronco 2d SAS 7sp(AB) High Tow Modular Hoop
. . . . . the charging system is undersized...
The Bronco has a 240a alternator, more than enough amps to keep *dual* H7 batteries in a big-block diesel fully charged, so not lacking in that respect. How it uses those 240a is another story. I've monitored the voltage on the Gauge display a few times. The voltage, on occasion, will sometimes hover in the 13's, even when the battery is significantly discharged (<12.2v). It typically takes >14.0v to charge an H7 battery relatively quickly. Sometimes it will hover in the high 14's and low 15's when the battery is completely charged (12.7v). No rhyme or reason to the Bronco's charging algorithms
BigBlue7
BigBlue7
New Jersey
Just went to get some gas any my voltage wasn't bouncing around as much, but peaked at 16.2!
