Multiple alerts/warnings while driving today
BroncoReb
MS
Bronco Outer Banks & Bronco Sport Big Bend
So I was driving my month and a half old OBX down the highway with the cruise set at 72 (in normal mode), and all of a sudden I got alerts popping up for ABS and pre collision assist warning disabled. The digital speedometer reading immediately after the alerts popped up was reading around 30mph even though I was still travelling at normal highway speed at that point- after 5 seconds or so it returned to the correct speed reading. (the abs and pre collision assist warning lights stayed on) I pulled over at the next exit and stopped to try to figure out what was going on- after stopping I got another alert for hill start assist as well as a park aid failure. I also noticed Goat modes are now unavailable as is cruise control. Not noticing anything unsual in how its driving/handling other than the functions being disabled. I dropped it at the dealer on my way home so hopefully they'll have an answer/fix for me soon. Anybody experience anything like this?
edit to add- I forgot to mention i had a service advance trac warning light pop on as well during all of this
elnorte
Seth
Dakota
I've had all of those alerts pop up once, about a month after I got my bronco. With that said it only happened once. It still works fine.
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak, 2024 2 door BB Sasquatch
Happened to me once. I turned off and back on, it went away and never came back
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Check the three bolts in the fuse box under the hood to make sure they are right. Also check your ground cable on battery mine was loose when I got mine.
Dustin
I've had the same thing happened to me but it seems to only happen when I turn on the Bronco. I've been trying to isolate it and film it but I feel like it has something to do with the electronic parking brake. I say that because the first time it happened I had parked in a parking lot, didn't engage the e-brake, sat there for 10 minutes and then started the Bronco again. After I OK'ed all the warnings, I noticed the e-brake was set.
Thanks for posting this though, I was just logging in to post the same. Following this thread now to see if others experience the same thing.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there – send a message to us with your VIN and approximate mileage. I’ll look into this for you. Thanks!
BroncoReb
MS
Update- Got her back from the dealer today. Rear left wheel speed sensor in the axle was bad.
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
This exact thing(s) happened to me yesterday. Three weeks until my dealer can get it in :mad:
Darrelm13
Darrel
2022 Ford Bronco
Mine did the same thing this morning 🤬
dblev
D avid
Clarksville, TN
2019 Tacoma TRD Off-Road
I am having the save issue in my 21 Bronco FE. Would you look into it for me? VIN is: 1FMDE5FPXMLA20938
I was driving yesterday and exited off the interstate and while stopped, several errors started being up, and a vehicle would no longer accelerate. Following popped up in this order.
-4x4 Off
-Service Vehicle Soon
-Service advance Trac
-Check 4x4
-Pre-Collision assist not available
-Service advance track
If I turn it off for a few minutes and turn it back on it is usually fine, however, this is incredibly dangerous because while driving it just stops accelerating. You still have power brakes and steering. It's just almost like it's bricking itself
Ducati1098
-4x4 Off
-Check 4x4
https://www.bronco6g.com/forum/threads/ford-motor-company-announcement.106495/
