Multiple warnings on dashboard
bmack
Brennan
Houston
Ford Bronco Big Bend
So, I know I have seen it here before. Yesterday I got a no key detected, while my key with fresh battery was right there. The service vehicle soon, service advance trac, then on my iPhone I got a the power train control system has detected an internal software level incompatibility issue and requires service. As well as powertrain or four wheel drive fault. So I dropped it off at a ford dealership. This is the second time. About two weeks ago I had pretty much the same thing happen. Multiple errors. I brought it to ford. The service advisor told me that there was a software update and that if you are driving car at that time that this can happen. She had the tech update the Bronco then set the auto update to happen at 1:00am. If the tech did the update, why is this still happening? Can anyone who had something very similar give me advice ? I don’t know if service advisor is leading me astray. Also, when I would try to start or stop my vehicle it would not listen to my command of pressing the start/stop button.
Dan-O
Dan
Fountain Hills, AZ
Haven’t had issues like this myself, but many threads on here with similar issues often point to a declining battery. Since you took it to dealer, I would like to assume they checked battery??
bmack
bmack
Brennan
Houston
The service advisor on round 1 did mention this, however when I went to pickup she started in the update. I would assume maybe ?
