Swing Gate Storage Bag Options?
swamp2
And a trash bag one that accommodates the rear camera. Please, someone make this...
Bschurr
NY
I was going to order one of these until I saw it is not compatible with Raptor: https://www.ford.com/product/molle-grate-system-for-swing-gate-p2805100505
Was hoping to get some suggestions on some similar ones that will work with Raptor- Thank you!
I installed that on my Raptor and it fits fine. In fact, there are many Ford parts that indicate “Not compatible with Raptor” and they fit & work fine including the factory soft top & FP winch kit.
NB - I modified the Molle Tailgate install on both my Badlands & Raptor by utilizing some zip screws across the top seam to provide a better connection to the tailgate and stronger carrying capacity than just the provided clips/straps. I could have used nutserts but the screws work just fine and the resulting holes are covered by the plastic trim is you decide to remove it so there is no visible damage either way.
Buy with confidence.
shane_02112
shane_02112
Shane
Georgia
F150 King Ranch, Bronco Raptor
Thank you!!
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
DewarT
Todd
I also have this on my Raptor and plan to do what you note above. It clips on and has some doubles sided tape which was not up to the job. 6 sheetmetal screws or nutserts/bolts should do well.
Ft. Worth Rob
Rob
Ft. Worth
BMW X7, Bronco OBX
I have this and not the biggest fan. The whole panel sags once weight goes on.
I agree it sags. I had an upholstery shop sew a Velcro strip across the entire top edge and attached the other side of adhesive Velcro to the tailgate with good results.
shane_02112
shane_02112
Shane
Georgia
Thank you. Seems like a really good idea and use of space but it’s got to be functional
shane_02112
shane_02112
Shane
Georgia
Thank you! Ford is costing themselves business 😀
shane_02112
shane_02112
Shane
Georgia
Thank you- I have not purchased anything yet, still looking at different products.
