Sway bar disconnect options
Anthony
2021 Bronco Wildtrak 2 Door
Any other options out there besides the ACfabs for front sway bar disconnects? If you have the ACs or any others, what are your thoughts? Just bought a new Wildtrak 2 door and obviously didn’t do my homework, just realized only the Badlands and FE have the auto factory disconnects.
0ne
Nate
CO
Flex
Take the bar off and send it, 1st editions got disconnect too
grayshadow
Charles
Humble, Texas
A couple of wrenches and some zip ties is all that’s needed.
Aztec1382
Sam
F350
Definitely Need more options
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
The AC Fabs are fine. Oscar is great and super personable. Mine are making all sorts of noise all of a sudden - I thought it was change of weather. I usually keep them greased up a bit, but it’s not helping. I’m hitting some trails in the morning and plan to double check the o-rings are still intact. But, otherwise - they do what they’re supposed to and are well made. Obviously wish they were cheaper - but, again - I’m happy to support his small brand.
Oscar was also super helpful when I was picking his brain about trails in/near Big Bear while we were visiting over the summer. A true community focused guy.
ArizonaWildtrak
Anthony
Ordered the AC fabs from Oscar. Hopefully some more (cheaper) options soon.
kodiakisland
Arkansas
Just one nut per side. My small impact wrench makes quick work of it.
NORCALGXP
Sacramento, California
2017 Raptor
Hi I have the Ac Fab on my two door and I have to either just leave them undone or go back to stock the noise is really bad after about 8 months. I drove most of the end of summer and had forgot to hook them back up, didnt really notice the sway, but when I went to 37s thats when i notice that they were not attached.
Question if using a impact wrench how do you hold the middle of the bolt with a allen wrench to keep it from spinning.
See you in Moab. Thanks
Frankie945
Frank
Louisville KY
Q50
I used a pair of channel locks to hold it while using my impact to tighten down. Pain in the butt but it worked.
redone17
Cold Spring, NY
Rubber O-ring? Lubed up? Noisy otherwise.
UniBroncorn
2022 Bronco Raptor
If it is a 2023 then you also got better suspension than the badlands.
NORCALGXP
2017 Raptor
redone17
Cold Spring, NY
Thanks, I will give a look and check it out.
There should be a rubber o-ring on the pin between the heim and the lower mount (I found 7/16” fit snug and are nice to have on hand). Then I just keep it lubed with Fluid Film (I’m sure there are better solutions depending on your weather conditions).
