Sun Visor Warning Labels
Raptor18
2020 F-250 Tremor, 2021 Bronco
Has anyone pulled these off yet? Do they remove easy and clean?
MacDonald_Photo
Jamie
Eaton Rapids, Michigan
2021 Badlands
TurnerNHooch
Patti
San Jose, CA
95 YJ & all the F150s
I have not, but I did see that one of the PPF companies has a black vinyl cover for them. I'm still too nervous to take off the nitrogen and MAP stickers....:p
Raptor18
Raptor18
I hope someone has a solution to these ugly things!
Rappygraphics made a vinyl cover for the Raptor owners, but I’d prefer to pull’em if it’s easy.
MacDonald_Photo
Jamie
2021 Badlands
Man, they don't seem easy to just peel off.
It's like they are embedded in there.
Scott1911
Oklahoma
2 Door BadSquatch
If I ever get a bronco I am going to try this. I used a heat gun on my Jeep.
<snip>
Method #1
Even better and easier than removing the visors is this little trick I tried today that worked to perfection.
Simply pull and unsnap the visor from its stowed position and swing it around as if you were trying to block the sun from the side window. Now rotate the visor so that the sticker side is facing up. The visor is now in a perfectly horizontal position.
Now take a kitchen paper towel and fold it such that it will just cover the area of the sticker. Now soak the the paper towel with Denatured Alcohol (that's what I used) and simply set the alcohol soaked paper towel over the sticker. Next, take a thin plastic bag - the kind you get at the produce section - and slip it over the entire visor and twist and tape the open end shut so that you seal everything inside, preventing the alcohol from evaporating.
Take a nap (that's what I did, truth) and after an hour or so remove the plastic wrap and simply peel the now wrinkled sticker off. Voila! It comes off intact! Amazing!
There is, however, some residue remaining that will need to be cleaned up. But I'll wait until tomorrow to do this, just so the vinyl can recover from the sudden shock of fumigation. Seriously, the vinyl needs to rest after this shock treatment.
Sticker Removal
MacDonald_Photo
Jamie
2021 Badlands
VelocityBronco
E
I saw those (that guy makes some cool stuff) and I guess they are "less" ugly than what is already there. LOL.
I bought them from Stickerfab, they are way better than looking at the ugly factory stickers, and I don't even notice them anymore. They send a 2nd set, so if you screw up or want to redo them, you have backups!
Use my discount code: VELOCITYBRONCO and save 5% on set.
BadSquatch77
Mississippi
2015 F150, 2021 Ford Bronco
I just used black vinyl tape to cover the stickers on the visor and in the door jams. Can't even tell they are there.
TurnerNHooch
Patti
San Jose, CA
I have a visceral reaction to even the slightest residue of adhesive. I may settle for "less ugly", in the meantime I will watch and see the replies here for an acceptable solution for removal.
Raptor18
Raptor18
Why can’t the just put the stickers on the inside of the visor?
Its like that dickweed Johnny whatever English accent iPhone designer guy… “we made it beautiful, sleek and out of glass”. Yeah, just so everyone slaps on a 1” thick Otterbox defender case on the biyatch.
Knownman
Santa Clarita California
2021 Bronco Badlands Sasquatch.
