Shorter Sun Visor?
MNBigfoot
MN
Not sure of the dynamics at play here but pointing it toward you should work unless you're completely shrimp-shaped.
If not I can only conclude you're using it wrong. 🌞
If i were a betting man, I'd say either is head is rubbing against the roof, or he's isn't understanding what he's being told.
JC71
Jon
Columbia SC
2026 Bronco
If you have a friend with a 3D printer you can just print a clip. with a part that hangs down. I did that and also included a camera mount.
Lucy
Rene
New Orleans
2023 Bronco
I'm 5'7"/8" and have the same issue. It has to do with the angle of the windshield. Sometimes I can't see traffic signals unless I duck down to look. I'm considering a tint strip (if anyone has it how does it work well?).
Ratfink33
Chicagoland
2024 Bronco Heritage Limited 2 door
I am only 6 feet tall and when I flip down the sun visor it’s too low by maybe 2 inches - even with it flipped against the windshield. I can’t imagine that anyone that is taller can use the visor at all. Does anyone make a shorter replacement? This is a 2026 SAS.
Thx!
As a shorter man of 5'7" I noticed the visor issue immediately. I took a whole different approach to the visor concern and just tinted the front window the whole way down. Illegal as hell, but problem solved! Lol.
But in reality, you could just get a limo tinted eyebrow piece for your front window and that is perfectly legal in 50 states. Easiest solution to your issue.
totaljustice
Kevin
Middle Sackvegas, NS
Good grief - I’m not an idiot.
My post plainly states - even when it is tilted as much as you can “hitting the windshield” ….. it is too low. Exactly as others have stated replying to my question.
He means just dropping the visor down a bit... so that it's pointing toward you but down slightly.
GI_Jo_Nathan
Jonathan
Bronco Naughty Pines
Jerry
Scottsdale AZ
2022 Bronco
I'm 6-1 and I totally get what you're saying. But agree with VAtruck, I rotate the visor away from the windshield, it looks like its poking you in the face. It works fine for me.
My other bronco buddy took his visor to a shoe repair guy, and they cut it, (looks great). He had to do the other side because of the look. Now the visor is to short for his wife passengers side. Hope you find answer.
MNBigfoot
MN
The same solution that everyone else in this thread mentioned, works with that problem also.
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
I wish someone made a visor with about 6-8" more extension for the 2 Dr...... to catch that annoying gap at the back of the window when the sun is on the side... 🫤
kodiakisland
Arkansas
I only flip mine down as much as I need it. It’s not all or nothing.
My wife is constantly complaining about my visor being too long. No way in hell I'm cutting it back though.
Eldowerks
Minnesota
Bronco ‘24
Did you know you can partially rotate the visor as far as you need to block the sun? It will be at an angle but that's fine.
Yup! I’m 6’-3” and that’s what I do too, have the visor tilted toward me rather than up against the windshield. Tilted toward the driver also makes a little better sight-angle for seeing overhead stop lights.
But, hey, some people miss the obvious…
