Sulfur smell upon acceleration ?
Jeff Lebowski
SoFla
Range Rover Sport SVR 2020
Has anyone had issues with a smell entering the cabin when accelerating ? I have a 2.7 Wiltrak with the Ford performance tune and a catch can. I also installed the arb rear diff cover but doubt that is contributing to the issue. My fear is that it is the cat not being able to handle the increase in fuel from the tune…. Any thoughts ? It seems to be getting worse.
Ground_zero298
Scs michigan
If your laying into it and getting the smell, it’s just burn off. Cats should hold that tune just fine. It’s not a aggressive tune. It will go away.
Dream_Solventless
Zach
22’ Bronco
2.3/auto and I get a pretty strong sulfur smell at WOT but I’ve just chalked it up to the cats loading up because I almost never floor it.
I can’t usually catch a whiff if the windows aren’t open but if I have any windows cracked it’s pretty strong
Jeff Lebowski
Jeff Lebowski
SoFla
Yeah, when the top is off the smell is very strong….
GaryB2220
Gary
Wellsboro PA
Only when the wife had pad thai the night before. Thank God for MGV. Jk
Jdc
Jon
Massachusetts
Bronco Badlands
Did you fill up with diesel🤣
Jeff Lebowski
Jeff Lebowski
SoFla
Man….this thread has been super helpful. Awesome stuff for sure !
Mattyfly42
2021 4 door 2.3L MT
I get the same smell. I didn't notice it until I put on a new exhaust system. Its only when I get on it. Not bad unless windows are down or top off. Keep hearing its burn off but im at 7400 miles think it would be burned off by then.
Jeff Lebowski
Jeff Lebowski
SoFla
Did you take it to the dealer ?
330SMG
Dennis
Hurricane Alley
16 F150 ,89 325i and 72 Dodge Charger SE
100% normal on a modern car with mediocre gas. Just some Sulphur dioxide side effect of cats and some impurities in the gas.
Change to a Top Tier Gasoline or gas stations and see if it goes away.
Jeff Lebowski
Jeff Lebowski
SoFla
Thanks for the insight. I’ve been using 93 the entire time I’ve owned the Bronco. Ive owned many cars and never had rotten eggs fill the cabin… Is there any benefit to getting a performance catalytic converter ?
thenewjs
Archie
Braptor
Did the OP have beans!!!!
FoxFour281
Kelly
Central Valley, CA
02 Mustang GT, 02 Expedition EB
The factory cats are fine, no need to change them out on a FP tune. I'm assuming you are going near or full throttle and then smelling sulfur? That is completely normal when the pcm richens the fuel mixture.
Ford Bronco Sulfur smell upon acceleration ? 1668020021142
Jeff Lebowski
Jeff Lebowski
SoFla
I am not accelerating at full throttle. The smell occurs early in the rpm curve.
