Bucking on Acceleration
Tacanta14
Tacanta14
Wasichu
Pie Town, NM
2022 Black Diamond 4 Door 2.3 MT
Sounds like the transmission issues my Daughter's Focus had. Yes that was the DPS6 dual-clutch transmission but the similarity is eerie.
Hope she had it taken care of, and if so, what was the fix?
Tacanta14
Tacanta14
Wasichu
Pie Town, NM
My 6 cylinder experiences uneven acceleration at times mostly at lower speeds. Not quite to the level of “bucking”. I’d be interested in hearing if your dealer finds anything.
I'll post if I have any followup info.
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Mine has done this a handful of times in the past two years. The instances are very spread out and when I took it to the dealer for the 7MT synchro TSB they couldn’t duplicate it. Definitely some gremlins running around
hellahella
Adrian
Nevada
Ford Bronco
I’ve had this issue also, and I read from another thread that the only resolution found is to update the PCM module.
I advised the dealership to do exactly that but they couldn’t reproduce the issue after having my Bronco for over a week.
ne13thdream
Crystal
Montgomery
Bronco 23 VB
I literally just dropped mine off today for the same thing... its a 4dr 23 Black Diamond 2.7 with almost 10000 miles on it. Mine feels like it gets stuck between 2 and 3 and the RPMs go nuts and then it jumps into gear. I can really tell it in sport mode!
Mustbeheresomewhere
Micah
2012 Chevrolet Silverado, 2022 Bronco Badlands 4D
Mine has done this intermittently in 1st gear only. No rhyme or reason as to why. I had the Ford Performance tune installed in December and have not experienced the bucking since. Could be coincidence, time will tell.
thesocalexplorer
Joe
Southern California
I've experienced this since new also. At just under 19k miles. I've noticed it happens on a lukewarm engine with oil temps around 100-120*F. Taking it out of gear, coasting in Neutral for a split second and re-engaging the gear and/or upshifting has fixed it 100% of time for me. Gotta love the buckin' bronco phenomenon that us 7MT owners get ;)
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
I can say much the same thing - would see if very rarely in 1st on my 7Mt (thought it was me being squishy on the clutch at first) but haven’t had it at all since installing the Ford Tune
Dialtone
Twilight Zone
Bronco Big Bend Mid
Three clutch replacements then finally a trans. Traded it in on her Mustang Graduation present. Never been a Ford guy but that Mustang and the 2.3l in it convinced me to look at the Bronco. My Cobb Accessport would work on the Mustang so I'm hoping they can get it working for the Bronco.
bellboyfab
So-cal
‘22Bronco ‘93 C3500
Ive had this happen multiple times with with almost these exact same conditions. Typically at nite or colder days so I have always chalked it up to not letting the engine warm up but am interested to see what others have experienced.
Tacanta14
Tacanta14
Wasichu
Pie Town, NM
You'd think that after the 1st or 2nd clutch replacement they wouldn't have done a 3rd, so I guess they fit the definition of insane! Had an F100 back in the early seventies, which was a good truck, then a Ranger in the early 90's, which was not a good truck. Having regrets about getting the Bronco, and the 2024 Tacoma Off Road will be my next vehicle! Hope the Mustang is running well!
rret
rick
ct
frontier, jetta
Can you please send over a message with your VIN and the name/location of your local Ford dealer? I would like to take a look at your acceleration concerns on my end.
have the same problem. 2021 base Bronco - 2.3, MT. how can I get my VIN and dealer to you? thanks.
Ford Motor Company
Dearborn
Good morning, Rick! I would be glad to help you out with this bucking concern should you need further assistance. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
