Sulfur smell upon acceleration ?
JohnnyBronco
Pennsylania
X4
I am not accelerating at full throttle. The smell occurs early in the rpm curve.
What fuel are you using? Sulphur smell should not come from 91+ octane Top Tier gas. If you are buying at a discount station that's the problem.
Edit Sorry, saw you are using 93 but from where, did you switch stations or did they fill underground with wrong product since it does uappen
Big Boss
Outer Heaven
Bronco Big Bend
Thanks for the insight. I’ve been using 93 the entire time I’ve owned the Bronco. Ive owned many cars and never had rotten eggs fill the cabin… Is there any benefit to getting a performance catalytic converter ?
Who's brand of gas are you using? You could do 330 said and switch to a top tier brand and see if that makes a difference. I used t never think much about the top tier branding but always used a name brand. I have noticed with the bronco I do get considerably better MPG when I use top tier from Shell or Mobil VS BP/Amoco
Jeff Lebowski
Jeff Lebowski
SoFla
Range Rover Sport SVR 2020
Usually I fill at the same Mobil location.
Mattyfly42
Matt
2021 4 door 2.3L MT
I've been using cheap gas. Ill try the good stuff.
Jeff Lebowski
Jeff Lebowski
SoFla
I smell it under acceleration and when on the highway a lot. It's pretty annoying. I'm wondering if I get a aftermarket exhaust that comes out the corner more will help? Any new info OP on if what you tried worked?
I actually stopped noticing it… when I have the window open it’s more
Noticeable, but beyond that I don’t pay attention to it….
Gtrekker
Gary
NJ
I did see if you mentioned your miles... how many do you have on the cats now?
Mattyfly42
Matt
2021 4 door 2.3L MT
Starting putting better gas in and don't notice it. For now. We will see when the weather gets better and the top is down.
Orca5150
Christina
Orange County
Ford Bronco
Hi, do you still smell it? Mine is a 2023 Black Diamond 2.3 automatic, and it smells like sulfur when I accelerate. I'm in Safari top mode, and it's very strong with no back windows. Oh and I have 11,000 miles
