Sub Rattle GONE!!!
Bronto.41
Clay
Sarasota, FL
22 Bronco
I have the b&o system and have been fighting the sub rattle try all the shortcuts. Read thru a sea of threads here and tried a bunch. Finally the wrapping the sub box and filling it with poly insulation worked 100%!!! Before i could maybe get to vol 10, bass 30% max before rattle. Now - can do vol max, bass max ( not that i’d have at that - but tried just to hear. ). Finally can jam!!
Ford Bronco Sub Rattle GONE!!! EB6448FB-A1C8-4D37-8CB7-F949ADFD7F3A
Ford Bronco Sub Rattle GONE!!! 0BE6A0A2-3775-43AB-BF0B-69274E88B3D1
Mason09
Mason
Orange county
23 4dr Bronco Badlands/22 Expedition Stealth
Looks great, this is what I want to do as well! Was it tough taking out the panels to gain access to the sub?
Bronto.41
Bronto.41
Clay
Sarasota, FL
22 Bronco
Not too bad - whole project took like 2-2.5 hrs at most.
- removed floor, then side (mainly pull)
Good luck, it’s worth it!
adamruiz2001
SoCal
Ford SVT Lightning
Nice, but you did all that work and didn't replace the sub with something better?
Bronto.41
Bronto.41
Clay
Sarasota, FL
22 Bronco
No I didn’t. - i just replaced all but the sub. was holding off. to gain funds if needed. From what i’ve read there really isn’t just a sub swap. It would need to be sub, amp and then messing with forscan? If so i will be waiting. If need be remove in future not too bad. The main thing for now was to get rid of that Rattle.
adamruiz2001
SoCal
Ford SVT Lightning
Totally understand, I was just playing with you. I need to get to it also, I have a replacement sub (8" Kicker), the KIcker key amp and some kilmat. I don't think you have to do anything with Forscan. 🍻
My ultimate will be the JL stealth box and the MO DSP amp. Just need the money to do it :ROFLMAO:
mhtucker78
Matthew
VA
2023 OBX Bronco
[/QUOTE
How much kilmat did this require?
Ford Bronco Sub Rattle GONE!!! IMG_8183
BlueBoy
Martin
CA
1989 Bronco 351W
Just the smaller box of kilmat and you didn't need to wrap anything else?
Bronto.41
Bronto.41
Clay
Sarasota, FL
22 Bronco
I wrapped behind box in cubby as well. was a tight fit when done. And poly fill inside sub box
35tires
'23 Bronco, '21 4Runner
I know a person working o .5 sealed that fits in the factory spot that will fit a shallow mount 10. If it all pans out, I'll be running that in place of my current jl w1 8 inch.
The 10 I'm going to use is from digital designs. 600 watts and sounds stupid, and .5 will work for sealed with it. All of that for less than the stealth and my best guess will be a better sound, sound quality, and save you a few hundred bucks.
adamruiz2001
SoCal
Ford SVT Lightning
Keep us updated! 🍻
mhtucker78
Matthew
VA
2023 OBX Bronco
Completed my wrap tonight…
Ford Bronco Sub Rattle GONE!!! IMG_8194
Ford Bronco Sub Rattle GONE!!! IMG_8198
the314boss
St. Louis
2023 Bronco Raptor
nice work!
question: outside of being rid of the rattle (huge win) can you tell a difference in the bass response/crispness of the woofer? was curious if it improved the sub sonically as well as being done with the rattle battle.
Bronto.41
Bronto.41
Clay
Sarasota, FL
22 Bronco
All I can say is it does sound better - Deeper and better response although not a whole lot. For me it is great right now - may swap later.
