Stupid Plastic Screw Clip Alternatives?
KABQ
Aaron
Albuquerque, NM
Does anyone have any recommendations for an easier alternative to these stupid clips? Or do I just keep a bunch on hand since they're so cheap?
It seems like I have to replace at least 1 in 5 every time I have to mess with them, and they're just a huge hassle to remove.
Ford Bronco Stupid Plastic Screw Clip Alternatives? images(56)
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Nail gun. That'll hold trim panels on and easier to install.
Disclaimer: Do not try this on your Bronco.
BigFootie
Wisconsin
I just slip a trim tool under them as I unscrew them.
Other option is to replace them with pop rivet. But I find those even more of a pita to remove! :cool:
Mlarv
TN
You could alway duck tape it.
I hate those clips also. I have figured out how to remove them without damaging a bunch. As stated above a trim tool under the larger piece, apply light pressure. Don't push the screw driver very hard, just sort of place it in the slot and turn very easy. At least that works foe me.
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
Of all the clips used on new vehicles, these are the easiest to remove and reuse without damage.
KABQ
KABQ
Aaron
Albuquerque, NM
I'm an aircraft mechanic, so I've drilled out my share of rivets. I'm pretty sure that's actually easier than these clips!
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Get you some FLEX SEAL tape. That stuff will hold nice
KABQ
KABQ
Aaron
Albuquerque, NM
They are super easy to remove when you know how to do it right. You can’t press in while unscrewing. Negative pressure.
Yeah I have an extra grippy textured screwdriver I use on them so I can kind of pull while unscrewing them and I use a trim tool as well if needed, and I still mess them up. My buddy was helping me yesterday and I think he destroyed EVERY SINGLE ONE he touched.
CM81
NA
I just bought one's off Amazon since I tend to break them even when using pry tool for them.
SHANUT
Craig
Hermann, MO
These work great. And they’re easily reusable.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
Napa has a push in that works much better than the POS with the screw.
